DigitalLumberjack wrote:
Yeah i forced turbo because it was the only way to make the rpi stable with extreme overclock. I changed the default setting to turbo for rpi1, and let user pass to extreme if they want
Pi 2 is not overclocked and you do not have overclock menu for now.
For the issue with controllers, i'm on it. No idea what it could be for now...
Thanks for the prompt reply and I'm glad to help. Keep me posted if you want data from the other controller setup. This one is with a Xbox360 Controller (official one not off brand) and a Retrolink Classic SNES USB Controller.
The other setup was with a USB converter but now that I got a SNES controller I was able to replicate the issue. I should try next a setup without the Xbox Controller to see for sure the Xbox Controller is an issue. If I'm correct I'll update this same post.
Update: I'm wrong it happens in all cases for me. I unplugged Xbox360 controller and plugged in my Universal USB converted that allows me to use PSone controllers and I kept my SNES USB controller plugged in and it still wouldn't allow me to use 2nd controller without press and holding a button on player 1.
Update 2: Just wanted to say since you're using a custom "Extreme overclock" you may want to put a menu disclaimer saying this Extreme clock may void your Pi's warranty if you choose to use it. Just a suggestion, because there will be people out there that will be very upset about that. I was at first
but I'm over it because: 1. it was $35 dollars. 2. Getting it repaired or returned if a technical fault would cost more money than probably buying a new one. 3. In the long run I really want to eventually buy a Pi2
. But I'm sure most would agree that knowing about the possibility of getting warranty voided with Extreme would be better than doing it blind and saying crud
Update 3: Did some research on ROMs. Due to it's questionable nature I'll be moving on from emualtion to other game options. Keep up the good work DigitalLumberJack.
Update 4: The Controller issue was specific to a ROM. So if you encounter and issue as mentioned above. Try out a different ROM with multi-player.
