mgoulart wrote:- I saw that you created a folder called "recalbox" with similar content from folder "retrobox", so all the configurations about the roms and gamelists is on this new folder. But I think that on the update process is missing an important step, get gamelists and setting and change the directory inside those files. I'm saying it because after update the system, all my gamelists are apparently gone but they are inside the folder "/root/.emulationstation/gamelists/" but the path inside stills using 'retrobox' and not 'recalbox'
Hi pal,
Yes i saw that after the update, many gamelists reference the game with a relative path, and i saw if you use an external scrapper or something you will have an absolute path... I cannot go back, the update has been pretty hard to make because of this folder renaming.
If you have access to your files, just use `sed -i "s/retrobox/recalbox/g" mygamelist.xml` on each one.
For the rom folder issue, you will have to update a second time.
I'm releasing today the 3.0.1 version, with 32x beta support, new buttons mapping for fba, etc etc...
I may suggest a fresh install of this one to get things working.
