Dijital
Sending command before RetroPi GUI boot
Sat Nov 29, 2014 2:17 pm
Hi, I would like to execute a couple of lines of command line code before the graphical part of the boot process kicks in. I'm from a DOS background and am new to Linux. Is there a file a can edit where I can add a couple of lines of command line code before the graphical mode kicks in?
Thanks!
mikronauts
Re: Sending command before RetroPi GUI boot
Sat Nov 29, 2014 4:25 pm
In Unix (and linux)
/etc/rc.local
is the rough equivalent of old dos AUTOEXEC.BAT
You can stick commands on the end, but most should have a '&' after them to launch in the background, and some may need to be SUID root (google suid for docs) if they need root access.
Example:
/usr/bin/mycommand &
Dijital
Sat Nov 29, 2014 6:15 pm
Thanks for the info!
Return to “Gaming”
