Neil Munday
Pi Entertainment System (PES)
Fri Sep 26, 2014 9:48 pm
Hi all,
If you are interested I have created a console emulator front-end in Python called the "Pi Entertainment System (PES)". The GUI is written in Python using PyGame, and grabs game meta data from theGamesDB.net. At present it only supports launching emulators that use RetroArch but others could be added if desired.
For the Raspberry Pi I have created an ArchLinux image with PES pre-installed. I decided to use ArchLinux as it provides a minimal OS installation and also was an ideal opportunity to learn about another Linux distribution.
The documentation and can be found at: http://pes.mundayweb.com
Images:
The PES Raspberry Pi image has the following features:
  • Graphical interface
  • Works with HDMI CEC enabled displays thus allowing you to use your TV remote control to navigate the interface
  • Automatic downloading of game cover art (requires network connection)
  • Works with USB game pads
  • PS3 control pad support via Bluetooth (requires compatible Bluetooth dongle)
  • Wired Xbox 360 control pad support
  • Automatic pairing of PS3 control pads
  • File sharing support to allow you to install new games (requires network connection)
  • Ability to "favourite" games
  • Provides console emulation via RetroArch for:
    • Nintendo Entertainment System (NES)
    • Nintendo Game Boy
    • Nintendo Game Advance Boy
    • Nintendo Game Boy Color
    • Nintendo Super Entertainment System (SNES)
    • Sega Game Gear
    • Sega Master System
    • Sega Mega CD
    • Sega Mega Drive (aka Genesis)
    • Sony PlayStation
Hope you enjoy it and I'd be interested to know about any bugs, feature requests etc.
Cheers,
Neil.
Edited: 18/02/2015 to reflect PES 1.2 changes
http://pes.mundayweb.com -> The Pi Entertainment System for all your gaming needs
Neil Munday
Re: Pi Entertainment System (PES)
Tue Sep 30, 2014 10:52 pm
Hi all,
Just to let you know the PHP script URL called by PES to grab meta data has been fixed so game data will now be downloaded properly.
There is no need to updated your Raspberry Pi if you have already written the PES image to your SD card as the error was server side.
Apologies for the error,
Neil.
welshy
Wed Oct 01, 2014 5:31 am
Neil Munday
Hello Neil, nice to see an Emulator SD Card Image for a Distro other that Raspbian! With your permission I will add this to the Emulation on the Raspberry Pi Thread, which will hopefully expand awareness of your Image.
"The list of things I have heard now contains everything!"
Neil Munday
Wed Oct 01, 2014 7:31 am
Hi welshy,
Please by all means feel free to add PES to the emulation thread :-)
Cheers,
Neil.
welshy
Wed Oct 01, 2014 11:58 am
Neil Munday
Thanks Neil, added to the Thread.
Hiradur
Sun Oct 12, 2014 9:04 am
Gotta check this one out although I'm horribly busy these days.
swshatkin
Tue Feb 17, 2015 4:58 pm
Hey there guys im having trouble installing PES on my SD card, i am a NOOB i was wondering if anyone could help, i am running windows and i was wondering if anyone has installed using windows, please let me know thanks. a tutorial installing would be great
welshy
Tue Feb 17, 2015 5:23 pm
swshatkin
Welcome to the Forum! You will need to write the downloaded image to an SD Card using Win32 Disc Imager, instructions in the Link below
Link - http://win32-disk-imager.en.uptodown.com/
swshatkin
Tue Feb 17, 2015 6:24 pm
do i need to install archlinux as well or just the image that is provided on the PES site
cacophony555
Tue Feb 17, 2015 6:26 pm
swshatkin wrote:do i need to install archlinux as well or just the image that is provided on the PES site
Just the image as it includes ArchLinux.
swshatkin
Tue Feb 17, 2015 6:29 pm
i have a B+ so i have to install the 1st one correct?
welshy
Tue Feb 17, 2015 6:31 pm
swshatkin wrote:i have a B+ so i have to install the 1st one correct?
Correct, the second Image is for the Pi2.
swshatkin
Tue Feb 17, 2015 6:36 pm
thanks so much welshy im gonna give it a try see how it goes, what would you recommend for unzipping the file?
welshy
Tue Feb 17, 2015 8:32 pm
swshatkin
No Probs! I use WinRAR as it will compress/uncompress most of the common formats, rar, zip, 7z, tar etc.
Link - http://www.win-rar.com/download.html?&L=0
Neil Munday
Wed Feb 18, 2015 12:33 pm
You may also want to check out the PES installation guide: http://pes.mundayweb.com/html/Installation.html
Any problems, let me know.
Cheers,
Neil.
swshatkin
Wed Feb 18, 2015 3:59 pm
Success i got it to work, I got everything running and i added games through my network but i ran out of space, is this due to non re sizing my root partition i tried to run the command
" /home/pi/pes/setup/arch/resize-fs.sh "
but it said doesn't exist or something along those lines, Is there something im missing here
Neil Munday
Wed Feb 18, 2015 5:32 pm
You are correct, the image when written to your SD card will need to be expanded in order to take advantage of all the space available.
You have also found a mistake in my documentation due to PES now supporting two versions of Raspberry Pi.
For the Raspberry Pi, please run:
sudo /home/pi/pes/setup/arch-rpi/resize-fs.sh
Once it has run you will need to reboot the Raspberry Pi and once it has loaded again you will need to run the command:
sudo resize2fs /dev/mmcblk0p5
If you then run:
df -h
you should see that your root partition has been expanded to use all the space available.
I hope to automate this in future versions of PES.
Thanks for reporting the mistake in my documentation - I've now fixed it.
Hope you enjoy using PES ;)
Neil.
swshatkin
Wed Feb 18, 2015 6:52 pm
awesome thanks so much for the help
AfterPartyLion
Tue Feb 09, 2016 4:52 pm
swshatkin wrote:Hey there guys im having trouble installing PES on my SD card, i am a NOOB i was wondering if anyone could help, i am running windows and i was wondering if anyone has installed using windows, please let me know thanks. a tutorial installing would be great
What if you want both pes and noobs
Neil Munday
Tue Feb 09, 2016 8:54 pm
I have to admit I've not looked into a PES/NOOBs set-up.
I can add it to the to-do-list if this is something people want?
Cheers,
Neil.
Return to “Gaming”
Who is online
Users browsing this forum: No registered users and 16 guests
