deaftolight
Fast Forward Button for Emulators
Tue Jul 15, 2014 4:26 pm
Has anyone else figured how to get hold fast forward working in the RetroArch NES and SNES emulators? I’m trying to set it up with the hotkey, so I can hold select and R2 to fast forward. This is the settings I put in my retroarch.cfg:
input_enable_hotkey_btn = "0"
input_toggle_fast_forward = "13"
input_hold_fast_forward = "9"
input_exit_emulator_btn = "3"
input_save_state_btn = "10"
input_load_state_btn = "11"
input_menu_toggle_btn = "12"
I can’t seem to get it to work.
DigitalLumberjack
Re: Fast Forward Button for Emulators
Thu Jul 17, 2014 4:21 pm
Hi !
You have to repeat the input_enable_hotkey_btn = "0" before each line you want to use with the hotkey.
Try to use input_toggle_fast_forward_btn instead of input_toggle_fast_forward.
Bye.
deaftolight
Fri Jul 18, 2014 6:05 am
Thank you! Unfortunately, that didn't work. Still won't fast forward/speed up.
It did; however, get rid of an error message that would come up before the ROM loaded that that key was not found. So even though input_hold_fast_forward is what is in the retroarch.cfg skeleton file, input_hold_fast_forward_btn seems to be the correct one. It's a shame that it doesn't work tough.
Return to “Gaming”
