Micha1982
Re: RELEASE: EmulationStation 2.0-RC1
Tue May 12, 2015 8:01 pm
I saw its a bit older and now I simply use the install-script...^^
Alles, was schiefgehen kann, wird auch schiefgehen.
faysalubit
Wed Jun 10, 2015 11:23 am
i just run emulationstation on RPi 2 and its working fine i jus want to know is there any way to start default game on startup rather than starting emulationstation ?
writerson
Thu Nov 26, 2015 6:06 pm
Hi there, i’ve build up my project with using raspberry pi2. now i am playing mame games with no problem with my ps3 controller (still designing a custom joystick-button front panel). My coin acceptor is working fine, but i am planning to add a relay-based hardware for accepting coin when a game is started from emulator. Otherwise, coin will be wasted if i use my coin in emulation station. I want to use my coin acceptor closed on default and when a game is started, i would like to trigger a relay and make it on open position.
I would like to ask you, is there any way to trigger a relay when a game is started from emulation station and close it on game close ?
Return to “Gaming”
