Morning all! First post but I'm not a
complete noob (just very nearly one) so hopefully it'll make some sense. I've been tearing my hair out trying to get
any version of uae4all working on my pi (the one that comes with retropie just about works, but only in X window, not from the cli) so I'm hoping this one will do the trick.
I just want to make sure I've got everything straight.
If I build uae4all2 from Sphaero's repository above, it should be:
- Working on the Pi
- A little slower than Chips' version, but with more features
- Slightly altered to bring up the menu on a press of F8
- Not able to use cli to load disk images.
Ok, here's my questions.
Does it still automatically load the df0.adf image from the program directory? If so, it should still be possible to use the method at
http://ledgerlabs.us/raspberrypi/retrop ... emulation/ to 'fake up' a command line start.
Secondly, apart from the key change are there any differences between the version on Sphaero's git and the version in binary form in the first post of this thread? Probably not worth building it myself if that's the only difference. If it is worth it, though...
Ummm.... how do I actually build it? I've got okay at navigating around using the CLI, running and writing bash scripts and so on but I've not really needed to go into that side of things so far.
Anyway, great project, guys, I'm sure I'll get it working some day! Thanks for bearing with an old fart who grew up with autoexec.bat and config.sys.
