So if this is too much to ask here please let me know...
Everything was working well for me, for weeks if not months. My son and a handful of his buddies were building away in his world but I couldn't leave well enough alone. Actually he wanted to update to 1.8 and I followed the instructions to update to Spigot 1.7 but then things went bad. He could no longer access his server and agreed to a fresh start with a re-imaged card. Back to a fresh formatting and writting of the MineCraft Pi 2.2 image and I get error after error. This is the same Raspberry Pi, the same PNY 8GB class 10 SDHC card (although I've also tried a SanDisk $GB class 4 card too, same errors). At initial boot either everything works and I make him OP and right after I get 'A fatal error has been detected by the Java Runtime Environment:...'
See pic of error on screen here:
https://lh5.googleusercontent.com/-ozow ... 194248.jpg .
I format the card, re-image and the same happens or after acquiring an IP address and after 'Loading Libraries please wait...' minutes go by and 'A fatal error has been detected by the Java Runtime Environment:...'
Should I download the image again, or is there another option?
