Seafood
GPIO Pins
Sun Apr 20, 2014 4:31 am
I wish to create an arcade table that has sixteen buttons and two joysticks. I believe that the number of GPIO pins on the raspberry pi is not enough for what I want. What should I get that expands the number of GPIO pins?
ame
Re: GPIO Pins
Sun Apr 20, 2014 4:50 am
Buy two USB joysticks?
Seafood
Re: GPIO Pins
Sun Apr 20, 2014 4:53 am
Wow. That is so simple. Thanks.
dan3008
Re: GPIO Pins
Sun Apr 20, 2014 7:08 am
Theres that option, or if youre dead set on making it yourself, look at the "kade"
Thats what i'm using :)
dan3008 wrote:Pays your money, takes your choice
Joller
Re: GPIO Pins
Sun Apr 20, 2014 2:28 pm
you could try soldering it to a keyboard core so that it will perform a keypress. (Tutorial) it is not that difficult and it is easy configurable. but it is way easier to just buy a usb joystick
i am sry if there are a lot of grammer mistakes
i am not from origin english
thak
Re: GPIO Pins
Sun Apr 20, 2014 9:16 pm
Recently a post been made about that http://www.raspberrypi.org/forums/viewt ... 78&t=74702
Check it out, it may be your answer/solution.
Return to “Gaming”
