squeeky
Enemy Territory
Sat Jun 02, 2012 1:33 pm
I just had a fantastic idea and fond memories of this game. Found the source code tweaked it and started to build it. I have managed so far to get about 10 mins in to the build process but obviously got stuck with unknown architecture. Anyone know if this one is possible because its based on Q3 i beleive.
Squeeky
diffo
Re: Enemy Territory
Mon Jun 18, 2012 7:42 am
news on Wolfenstein ET? :D
Khael
Re: Enemy Territory
Sun Sep 30, 2012 6:52 pm
Hi
Good idea!!!!
Any news??
mastermito
Re: Enemy Territory
Thu Oct 11, 2012 4:57 am
i'm waiting to my Pi to try it to compile ET.
Or are they any news?
I loved ET so much!
6ftdan
Re: Enemy Territory
Thu Feb 07, 2013 4:33 am
I think this is a brilliant idea. I just thought of it myself and see you all have as well. I may do this at some point soon. My key curiosity on this project is optimizing the GPU usage. Here's the source code to compile: https://github.com/id-Software/Enemy-Territory
Good luck all!
6ftdan
Re: Enemy Territory
Sat Feb 09, 2013 5:49 am
I could get most of the code to compile. But I ran into a snag.
Install Scons (scons.org)
- wget http://prdownloads.sourceforge.net/scon ... 2.0.tar.gz
- gunzip scons-2.2.0.tar.gz
- tar -xf scons-2.2.0.tar
- cd <scons directory>
- sudo python setup.py install --standard-lib
Then in the E.T. source directory edit out any instance of '-m32' from the text configuration files.
Then I tried the install by typing 'sudo scons'
It worked until it got to unix/unix_main.c
It complained about an unrecognized arch type and a non void reached. So if you edit the C code in the file to recognize the system I think you're all set.
Verfin
Re: Enemy Territory
Sun Feb 10, 2013 12:02 pm
Have you got any results? If so, could you make a quick step-by-step tutorial how to do it, for complete noobs like me.
svennd
Re: Enemy Territory
Mon Apr 01, 2013 4:30 pm
horrible day to post something but still.
have you seen http://www.etlegacy.com/projects/etlegacy ?
Its a maintained version of ET, it might be easier to get it working. I'm attempting a build right now :)
considering the specs it might be possible to run a very small dedicated server :) good for lan party's :)
Newk33
Re: Enemy Territory
Sun Apr 07, 2013 10:03 pm
i'll be watching this thread.. ET one of the few games that i still play regulary online (bunker4fun)
would be absolutly awesome if this manages to run on Raspi
Echtor
Re: Enemy Territory
Thu Nov 14, 2013 1:29 pm
I hang on splines/splines.h
see my changes here:
http://echtor.net/comments.php?y=12&m=0 ... 420-211213
Newk33
Re: Enemy Territory
Mon Sep 08, 2014 5:24 pm
maybe this source compiles better:
http://www.etlegacy.com/index.php?r=etl ... e/download
let us know if it does!
erajorma
Re: Enemy Territory
Thu May 21, 2015 7:00 pm
Has anyone got it working yet?
Forgotten01
Re: Enemy Territory
Sat May 23, 2015 3:02 pm
erajorma wrote:Has anyone got it working yet?
not yet, I am taking the source from the pandora version and will be trying to get that to work, but with my limited knowledge, my progress is the equivalent of stumbling through a house in the dark with no flashlight. :)
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
Scott Adams
Return to “Gaming”
