fo0t
jstest
Mon Feb 17, 2014 2:24 am
Been trying to run jstest to get 2 players running on PiFBA using my XIN-MO 2 player USB Adapter.
I have joysticks enabled and working great on mame4all
when i try to run
jstest /dev/input/js0
i get command not recognized.
when i run a search...
apt-cache search jstest
i see jstest-gtk
wtf am i doing wrong. i cannot find anything in the forums relating to my issue, all i see are alot of people running jstest and getting values from their chosen device.
im having some friends over tomorrow and would love to play 2 player marvel vs capcom.
Jessie
Re: jstest
Mon Feb 17, 2014 5:30 am
I haven't tried jstest but as a guy that loves capcom fighting games I will try and help. Have you tried...
./jstest
sudo jstest
sudo ./jstest
I will install it later tonight and see if I can help.
Jessie
Re: jstest
Mon Feb 17, 2014 5:48 am
I ran the command as you did and it worked fine have you installed it?
sudo apt-get install joystick
fo0t
Re: jstest
Mon Feb 17, 2014 3:15 pm
i figured it was already installed.
i installed the joystick package and am now running jstest fine. thank you for the help!
lsalcedo
Re: jstest
Mon Apr 21, 2014 7:47 pm
im having this issue. i cant figure how to config fba2x.cfg to play with my second joystick.
im using a xin mo enconder.
thanks
__Luffy_
Re: jstest
Thu Jul 25, 2019 4:53 pm
for me it says that Joystick is up to date but then when I run jstest dev/input/js0 it still says no such file or directory. What gives?
Return to “Gaming”
