LeSanglier
BrowserQuest
Fri Feb 07, 2014 5:34 am
This my little tutorial how to setup a BrowserQuest client and server :
http://framboisepi.fr/browserquest-jeu- ... -en-html5/
It is in french but very easy to understand the different steps.
Mon blog sur le Raspberry Pi : http://framboisepi.fr/
Pour avoir plus de chance d'avoir une réponse à votre question,
allez sur le forum français Rasberry Pi : http://forum.raspfr.org
Oldbitcollector
Re: BrowserQuest
Sat Feb 08, 2014 3:36 am
Cool! Doing this right now.. I used Google Translate to convert your instructions to English.
I'm in the ./configure & make steps.. It's been a while compiling. I'm thinking it might be time to brew some tea? :)
Jeff
My Ongoing Raspberry Pi Reference: http://www.ledgerlabs.us/raspberrypi
Oldbitcollector
Re: BrowserQuest
Sat Feb 08, 2014 3:50 pm
I followed all the instructions.. I'm unable to get a "health status" from the server on port 8000, but I can access the client on 8080. Naturally, I can't got further than entering my name as the server isn't found. Has anyone else had better luck with this?
Jeff
Re: BrowserQuest
Sat Feb 08, 2014 6:41 pm
LeSanglier wrote:Hi,
Why do you build node.js from source code rather than simply installing it with
sudo apt-get install nodejs npm
(which gets v0.10.25~dfsg2-2 & a whole bunch of other stuff)?
The only problem I've found with that is I needed to use
sudo ln -s /usr/bin/nodejs /usr/bin/node
to create the node command.
Forget that it gets a useless version of node that simply doesn't work.
Oldbitcollector
Re: BrowserQuest
Sun Feb 09, 2014 3:36 am
@DougieLawson,
I'm curious.. Were you able to get the "/server/js/main.js" to answer requests on port 8000?
I'm still hunting for a solution to this.. I've even restarted from scratch.
Jeff
Return to “Gaming”
