99wilksjam
Raspberry PI Gameboy MAME
Mon Nov 11, 2013 2:32 pm
Hi everyone,
Here is a quick look at a project im working on. It's pretty much a gameboy case and buttons intergrated with a pi and an arduino.
Pictures:
I've taken a few components off the pi to make it fit
I wired a Teensy 2.0++ to the contact pads on the front using an old IDE cable and connected the teensy to the pi via usb interfacing as a keyboard.
I used a 1.3Mah lipo and a 3.5" car screen with a 5v 3a ubec for the PI.
So far:
I also need put a balance plug on the outside of the case to tidy it up a bit. The buttons on the front are all working and correctly mapped.
Inspiration from :http://www.raspberrypi.org/phpBB3/viewt ... 4&p=301844
thanks
Trashking
Re: Raspberry PI Gameboy MAME
Thu Nov 21, 2013 1:54 am
How are you keeping everything in the gameboy do you screw it together?
lithium630
Mon Nov 25, 2013 1:24 am
how are you powering it off?
Return to “Gaming”
