dan3008
Re: 11/25 UltraSlim = Retro/Gaming/Q3|XBMC 12/13|Desktop + m
Sat Nov 30, 2013 11:00 pm
Takenover83 wrote:The script's are still there. Just with the .bak extention. Rename em to .sh if you want to use em. Also reinstall vnc via apt.
sudo apt-get install tightvncserver
I realised the scripts were still there, just after i'd copied them over from my previous install... do i ever feel silly lol
dan3008 wrote:Pays your money, takes your choice
Takenover83
Sat Nov 30, 2013 11:02 pm
ThunderZ wrote:Did you plan to support more hardware/console system with ultraslim for the next version or just built it around retroarch ? (not bad but not perfect in most case with the raspberry)
If alot of people want a certain emulator, I would have no problem including it. Although I did try to add the most popular.
dan3008
Sun Dec 01, 2013 9:46 am
Thunder, what other emulators do you want? I'm more than willing to help you add them :) Its quite easy. One day this next week, I'll add a tutorial for adding emulators
Takenover83
Tue Dec 03, 2013 7:34 am
New builds of xbmc (12/03/2013)
020110348
Fri Dec 06, 2013 3:55 pm
i read in past posts that joystick is disabled, have you found a way around that yet? can you post your solution if you have.
Takenover83
Fri Dec 06, 2013 8:10 pm
Joystick support is disabled in xbmc. There are ways however to use your controller with xbmc. I personally use the xboxdrv and map keyboard commands to the controller. Not easy to setup, but works well.
bsaundry
Sat Dec 07, 2013 5:08 pm
This is probably the stupidest question you're going to get in this thread. I just got my Pi, and never used Linux before (*ducks head*)
I've booted into UltraSlim and have configured my controller and updated the emulators I wanted to use. I've been able to use XBMC just fine.
I just cannot figure out how to actually get into the emulators themselves. :oops: :oops: :oops: :oops:
I must be missing something that is staring at me in the face, but for the life of me I cannot figure it out.
The options I see are:
01 - Raspi-Config
02 - Configure Joystick 0 Retroarch
03 - Update Emulators
ES Scraper
LXDE (Desktop)
Openbox (minimal desktop)
Quake III Arena
XBMC
welshy
Sat Dec 07, 2013 9:42 pm
bsaundry
Welcome to the Forum! I believe they only appear in the Menu if there are ROMS in the folder for the appropriate emulator (or in the case of PlayStation Image files).
"The list of things I have heard now contains everything!"
Oldbitcollector
Sun Dec 08, 2013 3:40 am
This is a "little" off-topic, but is there a way I can install your XBMC binaries into my existing Raspbian?
All I'm finding is really old binary instructions for doing this, and it looks like you have the most recent attached to the top post in the thread?
Jeff
My Ongoing Raspberry Pi Reference: http://www.ledgerlabs.us/raspberrypi
wheelerruss
Sun Dec 08, 2013 3:22 pm
Hi, I've just installed and setup Ultraslim and everything looks good so far.
However, I'm a bit of a novice when it comes to samba shares, and although in XMBC I can find my computers name, it says connection refused. I presume it's because I don't have the username of either my pi or the computer saved in a specific place.
Can anyone give me a quick couple of pointers?
Russ
monty_burns_007
Sun Dec 08, 2013 7:04 pm
First of all, this is a great distro where I can use Emulationstation and XBMC at the same time (sdcard).
Great !
The emulators are more rescent and run more stable than my old Emulation station home made version from 1 year ago :-)
So i guess i will be moving my roms to this version i think.
I had some problems setting up my logitech precision joystick config file (from old emulation station file), but now they work :-)
I only have 1 problem left and that is my IR remote control for XBMC.
Previously I used OpenELEC with my Harmony 525 IR controller.
This worked great out of the box on OpenELEC.
But it does'nt work on this distro.
I tried copying the file lircd.conf (that worked on openELEC) to this distro like you said:
Lirc (remote support) is installed and enabled. Just copy your lircd.conf to /etc/lirc.
But it doesn't work.
on terminal lirc get's detected.
I followed also: http://www.raspberrypi.org/phpBB3/viewt ... p?&t=26946
Here some logs:
pi@UltraSlim ~ $ dmesg | grep lirc
[ 11.703015] lirc_dev: IR Remote Control driver registered, major 248
[ 11.786194] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.751079] lirc_rpi: auto-detected active low receiver on GPIO pin 18
[ 12.755318] lirc_rpi lirc_rpi.0: lirc_dev: driver lirc_rpi registered at minor = 0
[ 12.755367] lirc_rpi: driver registered!
[ 14.194836] input: lircd as /devices/virtual/input/input3
pi@UltraSlim ~ $ ps ax | grep lirc
943 ? Ss 0:00 /usr/sbin/lircd --driver=default --device=/dev/lirc0 --uinput
2475 pts/0 S+ 0:00 grep --color=auto lirc
pi@UltraSlim ~ $ sudo mode2 -d /dev/lirc0
mode2: could not open /dev/lirc0
mode2: default_init(): Device or resource busy
pi@UltraSlim ~ $ sudo /etc/init.d/lirc restart
[ ok ] Stopping remote control daemon(s): LIRC:.
[ ok ] Loading LIRC modules:.
[ ok ] Starting remote control daemon(s) : LIRC :.
If I restart lirc I get more virtual inputx numbers?
[ 936.836464] input: lircd as /devices/virtual/input/input4
[ 941.364717] input: lircd as /devices/virtual/input/input5
[ 1026.338587] input: lircd as /devices/virtual/input/input6
If I kill the proces that used lirc and do : sudo mode2 -d /dev/lirc0
then I see the codes when pressing buttons on my IR remote.
So I think Lirc works, but XBMC can't see them ?
anyone got lirc working on this UltraSim distro ?
Thanks in advance
Takenover83
Sun Dec 08, 2013 7:14 pm
Is your remote not mapped to keyboard command's? If not, you might need a custom xbmc remote.xml. Try pulling it from openelec.
As far as the Samba issue goes, that sounds like you need to set up your share correctly on your pc. If it is using a password, make sure you tell xbmc what the username/pass is.
Anata
Mon Dec 09, 2013 1:50 am
hello Takenover83,
I would like to know how to install Libretro for Turbografx with UltraSlim.
i have trying to put the RetroPie binarie of mednafen-pce-libretro to UltraSlim , and Video is ok, but not the sound.
many lags with the sound under UltraSlim and not under RetroPie.
Do you have an idea to include mednafen-pce-libretro correctly under UltraSlim ?
grit
Mon Dec 09, 2013 6:56 pm
I'm using the mame4all_pi mame instead of the retroarch for this excellent image but have trouble getting my Xin-Mo Dual Controller to work. I read the tip about enabling it by device_joystick auto / device_joystick raw but can't really find those settings in mame4all_pi. I've done the jscal etc from the shell and the Xin-Mo works perfectly in the emulationstation itself...
Also - some roms work when I start mame4all_pi from the shell but not from emulationstation. Is there a BIOS override somewhere?
Thanks!
actudoran
Wed Dec 11, 2013 12:39 pm
hi guys! total noob here ... don't know if I'm doing anything wrong here but i just made an sd with v 1.5 and cannot get the wifi to work ... it seems that there is no wifi config in lxde or xbmc or anywhere ...
also qwake not working ...
how do I start the emultors ?
thank you all in advance !
welshy
Wed Dec 11, 2013 12:48 pm
actudoran
Not sure about WiFi (it may be LAN only?), I do know XBMC requires a LAN connection first to add the correct drivers for WiFi (Go into Settings, then install Add-Ons, then select Program Add-Ons and add Network Manager). Quake will require .pak files in the Quake directory to work. The emulators similarly, once you have placed a ROM or CD Image (for PlayStation, usually .bin/.cue) the requisite emulator/game title will appear in the Menu.
Takenover83
Thu Dec 12, 2013 6:01 am
Wifi works fine. You just have to configure it. I use wifi on 1.5 with my 2nd pi.
actudoran
Thu Dec 12, 2013 7:24 am
did manage to get the wifi up sudo nano style like in here: http://pi.oeey.com/
still can't figure out how to play stuff ... where do i get the roms and put them where?
xbmc got the superrepo but not much luck with stuff wanting to install and even worse luck with add ons installed but failed to start ... any pointers?
welshy
Thu Dec 12, 2013 11:34 am
actudoran
Due to the nature of Copyright Law please DO NOT -
1. Ask for ROMS
2. Ask where they can be downloaded
3. Post links to Download Sites and/or ROM files
However, they can be easily found by using your favourite Internet Browser, just search for, 'SNES ROMS', 'MAME ROMS' etc. Once you have located/downloaded your files there is a Roms folder in the Directory structure (just go into LXDE for ease of browsing) and place them inside. The Game Title in the appropriate Emulator should now appear in the UltraSlim Menu.
dan3008
Thu Dec 12, 2013 12:48 pm
ultraslim also has samba setup, so you can naviage to your roms folder from another computer on the network
actudoran
Fri Dec 13, 2013 8:33 am
Allright, I got it. Being a bit noobish, not meaning any harm ...
Got xbmc to behave finally,but, yahoo don't want to log on ... So all the clips relying onyoutube fail to open. Vimeo works a treat though.
Really love the distro! You got everything ...
Donkoopa
Thu Dec 19, 2013 9:12 am
Installed that Image after i got too frustrated.
Worked quite well. Well at least i was finally able to play games and movies without changing the SD card.
The only problem i have is that the games are lagging and i've used the fast overclock. I might try to use the turbo-config but if i remember correctly i already tried that and had a kernel panic on boot.
I also get a Kernel bug and system freeze if i plug in my Xbox 360 wireless receiver or boot with it plugged in my external USB hub.
One suggestion for the Image itself:
My TV supports CEC which turns my TV off automatically when exiting XBMC. You might want to turn that off.
welshy
Thu Dec 19, 2013 10:35 am
Donkoopa wrote:Installed that Image after i got too frustrated.
Odd, which emulators are slow? Also a new raspbian kernel/driver update is available which is much more stable and less prone to SD Card corruption at high overclock settings, see link
Here - http://www.raspberrypi.org/phpBB3/viewt ... 78&t=62235
Donkoopa
Thu Dec 19, 2013 4:32 pm
i did an rpi-update yesterday but nothing changed after that...
I'm testing the NES emulator with Tetris and the SNES emulator with Mario RPG.
Tetris runs smoothly... except the regular appearing lags every 3rd second or so.
I'm currently updating the emulators and see if that will help...
I'm running the standard "High" overclocking preset.
Return to “Gaming”
