Re: WIP: Playable Nintendo 64 Emulator Available
It should work on Pi2.
The build script detects if you are running on a Pi2 and will provide the necessary flags for ARMv7 and NEOM optimizations.
Hello all,
Extreme noob to Raspberry Pi, N64 emulation, and Linux in general. Earlier in the thread I've seen mentions of different settings in mupen64plus.cfg. When I open that file though in nano, my file only has about 5-6 lines under the [Core] section. Is there a 'recommended' or updated cfg file somewhere I could grab? I'm trying to tweak settings with the Rice plugin.
I also would like to be able to tweak the gles cfg file plugin, but it seems strangely devoid of information as well.
Unfortunately, it doesn't work for me either. I have the same problems as dennmtr from the previous page.ric_rpi wrote:It should work on Pi2.
Ktb and dennmtr -
I have ran into this issue before, I don't remember what I did to fix it.
First check how much memory you have to the GPU before you run mupen. It has to be 128 I believe.
Also, do you have the console ouput from the build script?
I always have gpu_mem set to 128 or higher unless I'm compiling something big. I've been running with 192, 256 or even 512 for some things lately. I tried all of those in my attempts.NF3RN0 wrote:Ktb and dennmtr -
I thought I might have a log from the script, but I'm not able to find it at the moment. I think I remember needing to modify RaspbianList_Pi2 to get it to work.
build.sh would always stop here with an error which was something like "make: pu=neon: No such file or directory":
video-gles2n64 ricrpi master , NEON=1 VC=1 OPTFLAGS=-flto -mfpu=neon
So i removed the "OPTFLAGS=-flto -mfpu=neon" part
I should probably mention that my attempts were on Raspbian Jessie with gcc-4.9. I'm going to downgrade to wheezy. I'm experiencing too many problems in general.
I had one other little issue. The build.sh script tries to detect gpu_mem here:
if [ -e "/boot/config.txt" ]; then
set +e
GPU_SET=`grep -c gpu_mem /boot/config.txt`
set -e
if [ "$GPU_SET" = "1" ]; then
cat /boot/config.txt | grep "gpu_mem"
GPU=`cat /boot/config.txt | grep "gpu_mem" | cut -d "=" -f 2`
else
echo "gpu_mem not set in /boot/config.txt"
fi
fi
Update: I downgraded to wheezy (though I'm still using gcc-4.9). I'm not sure whether the downgrade helped or not, but some other things certainly did. SDL2 had to be configured, compiled and installed prior to running the build and install scripts. I think the following should cover it, but it's possible that I'm forgetting some other changes I might have made.
~/software/build/mupen64plus/SDL2-2.0.3# ./configure --host=arm-raspberry-linux-gnueabihf --build=arm-linux-gnueabihf --prefix=/usr/local --disable-pulseaudio --disable-esd > configure.log 2>&1
~/software/build/mupen64plus/SDL2-2.0.3# make -j3 > make.log 2>&1
~/software/build/mupen64plus/SDL2-2.0.3# make install > make-install.log 2>&1
Remove the "OPTFLAGS=-flto -mfpu=neon" from RaspbianList_Pi2:
~/software/build/mupen64plus/# ./build.sh RaspbianList_Pi2
~/software/build/mupen64plus/# ./install.sh
ktb,
thanks for the hint on changing the raspbian list information. I built the mupen64plus on a weezy raspbian built. I was able to build and successfully install the package as well as get both the gles2rice and gles2n64 video plugin in the usr/lib/local ( i think) folder. Apart from the game not utilizing the full screen which can be fixed by modifying the config file, once i locate it, it appears to run properly.....a tip if your installing on fresh build before you begin the build you may have to install libglu1-mesa-dev...as before the mpu=neon error I received an error regarding openGL not being found.
update!! For some odd reason after a reboot, mupen64plus hangs when trying to open a rom at setting 32 bit video mode!....will try another fresh install and update.
Is this the same Mupen version that is included with RetroPie 2.6? I am having trouble getting n64 games to run on my Pi2, and I researching info on what the best emulator to use is. This sounds like it's good, but I believe the RetroPie comes with Mupen. Is this a fork, or the same one?
So i followed the build steps from
https://github.com/ricrpi/mupen64plus
and it gives me this. Not sure what to do, so if anyone has a step by step on how to fix this, please do let me know. I'm trying to get a working version for my pi2b weezy.
************************************ Building core library
make: Entering directory '/home/pi/n64make/mupen64plus/ricrpi/mupen64plus-core/projects/unix'
Makefile:107: Architecture "armv7l" not officially supported.'
rm -f -r libmupen64plus.so.2.0.0 libmupen64plus.so.2 _obj
make: Leaving directory '/home/pi/n64make/mupen64plus/ricrpi/mupen64plus-core/projects/unix'
CC _obj/api/callbacks.o
CC _obj/api/common.o
CC _obj/api/config.o
CC _obj/api/debugger.o
CC _obj/api/frontend.o
CC _obj/api/vidext.o
In file included from ../../src/api/vidext.c:38:0:
../../src/api/vidext_sdl2_compat.h:34:2: error: #error SDL is not build with OpenGL ES2 support. Try USE_GLES=0
Makefile:630: recipe for target '_obj/api/vidext.o' failed
make: *** [_obj/api/vidext.o] Error 1
My RPi needs a fan, heat will leech into the battery, so people saying I don't need a fan, don't understand how Li-Po batteries are affected by high temps. Cool pi = cool battery.
I would very much so like to see a Pi2/Pi3 Zero, power and size.
Read my last post. It should help you.Djinny wrote:So i followed the build steps from
************************************ Building core library make: Entering directory '/home/pi/n64make/mupen64plus/ricrpi/mupen64plus-core/projects/unix' Makefile:107: Architecture "armv7l" not officially supported.' rm -f -r libmupen64plus.so.2.0.0 libmupen64plus.so.2 _obj make: Leaving directory '/home/pi/n64make/mupen64plus/ricrpi/mupen64plus-core/projects/unix' make: Entering directory '/home/pi/n64make/mupen64plus/ricrpi/mupen64plus-core/projects/unix' Makefile:107: Architecture "armv7l" not officially supported.' CC _obj/api/callbacks.o CC _obj/api/common.o CC _obj/api/config.o CC _obj/api/debugger.o CC _obj/api/frontend.o CC _obj/api/vidext.o In file included from ../../src/api/vidext.c:38:0: ../../src/api/vidext_sdl2_compat.h:34:2: error: #error SDL is not build with OpenGL ES2 support. Try USE_GLES=0 Makefile:630: recipe for target '_obj/api/vidext.o' failed make: *** [_obj/api/vidext.o] Error 1 make: Leaving directory '/home/pi/n64make/mupen64plus/ricrpi/mupen64plus-core/projects/unix'
Ok now i'm getting:
Core Error: SLD_SetVideoMode failed: 0x5000000. GLX is not supported
Video Error: Failed to set 32-bit video mode: 640x480
I'm kind of pulling my hair out here, i'm not a programmer, and i'm not that familiar with linux, so i'm doing the best i can. When i got the pi, i was surprised by how so much stuff isn't ready to use, and everything needs to be compiled, modified, and all that stuff. installing 1 program can take 50+ steps.
If you wanted a 'Straight Out of the Box Solution' you're missing the whole point of the RPi experience and why the Foundation exists!Djinny wrote:When i got the pi, i was surprised by how so much stuff isn't ready to use, and everything needs to be compiled, modified, and all that stuff. installing 1 program can take 50+ steps.
"The list of things I have heard now contains everything!"
Maybe so, but i'm here, I wasn't prepared for this, but I'm here, and i'm doing what i can, and i'm asking for help. So if we can stop with the attitudes.welshy wrote:If you wanted a 'Straight Out of the Box Solution' you're missing the whole point of the RPi experience and why the Foundation exists!
About my GLX issue.. I installed SDL2 the way ktb showed, using the commands he did, same with installing mupen64plus. I googled, and installed dispmanx according to the instructions the best i could understand them.
Went to and did this.
https://github.com/vanfanel/SDL12-kms-dispmanx
-To configure for DISPMANX backend just run the MAC_ConfigureDISPMANX.sh script.
-Run make && sudo make install.
(-They won't work on (slow and bloated) X enviroments.) I mostly work from X, just get's complicated to even do simple file transfers using the prompt all the time.
I followed the instructions step-by-step, but I'm receiving an error when running the build file.
pi@RaspberryPI ~/mupen64plus-rpi $ sudo ./m64p_build.sh
make: Entering directory '/home/pi/mupen64plus-rpi/source/mupen64plus-core/projects/unix'
Makefile:101: Architecture "armv7l" not officially supported.'
make: Leaving directory '/home/pi/mupen64plus-rpi/source/mupen64plus-core/projects/unix'
../../src/api/vidext.c:43:23: fatal error: GLES2/gl2.h: No such file or directory
compilation terminated.
Makefile:601: recipe for target '_obj/api/vidext.o' failed
Any ideas? I'm kind of new at this. I'm running Raspbian on an RPI2
Proud Owner of a Raspberry Pi 3B and 3B+ running Ubuntu Mate
Hello
First of all I want to thank you a lot for all the job you've made on this emulator. I Bought my Pi especially to play with my old N64 games on my HD Tv.
I'm a big noob on Linux and raspberry and I'm fighting some night with it
What I would like to do with it is to use Emulation Station to manage my emulators only with a gamepad. At this time, I was able to do approximatly all I wanted instead of 1 thing :
Use Rice video plugin to play with mupen. Impossible to center the screen (it stay at the bottom left of the Tv) and fullscreen gives me a black screen (rom is playing as I can heard the audio)...
I had no problem with n64 video plugin but for some games in the compatibiliy list the rice plugin is written.
What I've done is to create 2 roms folders (one for games working better with rice and one with these which work better with n64) and I put in ES 2 N64 systems (one lauching mupen with specific command to run rice video and the other with n64 video plugin)... But At this time it feels more confortable to play with n64 plugin....
I hope one of you guys can helps me to solve this screen center issue, I ve made some research on the net but I'm not an english native speaker so sometime it's a little bit difficult to find what I want.
Hope that's clear enough and again a very big thanks for all you do on this work!
For those looking for a more "Out of the Box" solution then I'd advise using something like RetroPie, see:DjQC wrote:Hello
I'm a big noob on Linux and raspberry and I'm fighting some night with it![]()
viewtopic.php?f=78&t=54357
There's a bit of fiddling about getting started but there's information on how to do that on this forum and youTube, e.g.:
https://www.youtube.com/watch?v=lh0n5PWN2lI
Once you have RetroPie you can press 'x' before a game starts to configure video plug-ins. Your "bottom left of the Tv" issue can usually be fixed using the rice plugin with a lower resolution and video buffer. I start by using the smallest possible then iterating from there.
Is the R-pi running 64bit?
It's very unusual to run a higher bit application emulated on a lower bit processor. You'd need to have between 2x to 4x the CPU clock speed to run it fine.
More often a 64bit processor can emulate a 32bit (or 32 bit cpu emulates a 16bit) console just fine.
I'm surprised!
I'm surprised!
Not sure where you're getting this from, yes you need more power to emulate than the original system's specs, but even a 32bit system like the sega saturn can be tough to emulate.ProDigit wrote:Is the R-pi running 64bit?
I'm surprised!
A PC can emulate a 128bit system, infact the raspberry pi can emulate a 128bit system, the dreamcast. It's not perfect, but that's the fault of the software, not the hardware, if the pi was running android it'd likely play dreamcast at 75% speed easily(frameskip fills in the rest)
The rasberry pi emulates the n64 pretty freakin well. and when i say the pi, i mean the pi2.
heres a video of my pi2 gameboy playing LoZ OOT, it runs at 100% speed, 98% of the time, i rarely have slowdowns worth noticing. Only thing that doesn't work... lens of truth.... i'll figure out what to do with this..
https://youtu.be/BVgAnXKyXvU?t=4m42s
PS: If any of the people working on this emulator are taking requests, would it be possible to link the rumble feature to some sort of onscreen display. maybe box around the screen that's 0(off)-10 pixels wide(settable in the cfg) that'll blink when the game is supposed to rumble. Just for the stone of agony.
Djinny
you could have a try at building the kernel module that will support rumble for your controller on the pi. Don't see why it wouldn't work so long as the controller can get enough power e.g. from a powered USB hub.
hi,
i am using a raspberry pi 2 and raspbian jessie and followed the instructions here:
unfortunately it doesn't work and i hope that someone can help me.
first i got this error message:
then i installed:
then i got this error message:
so i tried:
and now i get:
any ideas?
isn't it ready for jessie yet?
make: Entering directory '/home/pi/NINTENDO64/mupen64plus/ricrpi/mupen64plus-core/projects/unix'
Makefile:296: *** No OpenGL development libraries found!. Stop.
make: Leaving directory '/home/pi/NINTENDO64/mupen64plus/ricrpi/mupen64plus-core/projects/unix'
sudo apt-get install libglu1-mesa-dev
sudo apt-get install libsdl1.2-dev
spock
Afraid I don't have a Pi2 to test but it does work for jessie on a Pi B. If you wish to PM me with the entire output from ./build.sh, I will take a look through to try and give you some pointers.
Mupen64plus uses SDL2 and the build script will compile it from source so that it can apply the correct flags for GLES support.
Hello, I too am trying from a pi2, here is the output you were asking for let me know what I can try.
Thanks,
./m64p_build.sh
make: Entering directory '/home/pi/Downloads/mupen64plus-rpi-master/source/mupen64plus-core/projects/unix'
make: Leaving directory '/home/pi/Downloads/mupen64plus-rpi-master/source/mupen64plus-core/projects/unix'
#include <GLES2/gl2.h>
Thanks,
./m64p_build.sh
Hi everyone,
I've wanted full speed N64 emulation on the Pi for a while now, so I've been working on a Mupen64plus graphics plugin specifically optimized for the VideoCore IV (and for other mobile GPUs as well). I've now got a 30 FPS Super Mario 64 (30 FPS this is the native framerate of the game, so it's 100% speed) running at the N64 native resolution (320x240). It's a hacked-up version of Hacktarux' old software plugin, so compatibility is currently poor, but speed is great. If anyone would like, I can clean up and throw the source code up on GitHub.
I probably won't have a huge amount of time to improve compatibility and accuracy, but I'm happy to accept pull requests or even hand off maintainership to anyone interested.
Hi Put the source code on github.
OK, I polished up the plugin a bit and posted it to GitHub:
https://github.com/tachiweasel/mupen64p ... -videocore
See the README file for instructions. Please feel free to contribute!
Partial compatibility list:
- Super Mario 64: very good, a few minor graphical issues, full speed
- Star Fox 64: good, a few minor graphical issues, some slowdown in non-critical places
- Mario Kart 64: good, a few minor graphical issues, some slowdown in non-critical places
- The Legend of Zelda: Ocarina of Time: playable, major graphical issues, occasional slowdown
- Super Smash Bros.: playable, severe graphical issues
- Banjo-Kazooie: playable, severe graphical issues, some slowdown in non-critical places
- GoldenEye 007: not working, severe graphical issues, major slowdown
- Mario Party: not working due to incorrect VI emulation
Just tried the github:
It was on jessie for a fresh pi 3.
First on Jessie we have GCC 4.9 already installed so in build.sh I modified following lines:
Then rebuild in mupen64 directory using "sudo ./build.sh"
No it works... but in small window only
But i didn't understand why i needed to change the SDL2 config
- if [ -z "$GCC" ]; then
GCC=4.7
GCC=4.9
- In file included from ../../src/api/vidext.c:38:0:
- SDL_CFG="--disable-video-opengl --host=arm-raspberry-linux-gnueabihf --disable-pulseaudio --disable-esd"
I get the same error if i compile SDL2 with X11 support on Raspbian Jessie... without X11 is goes further...dennmtr wrote:Code: Select all
Video: Initializing OpenGL Device Context. Core: Setting 32-bit video mode: 640x480 Core Error: SDL_SetVideoMode failed: 0x5000000, Could not get EGL display Video Error: Failed to set 32-bit video mode: 640x480 Core Status: Rom closed.
