Netram
Boot into Emulationstation
Mon Oct 14, 2013 4:40 pm
Hi I just started a project in which I will build a portable RetroPie machine but there is one thing I can't figure out, how do I boot strait into Emulationstation? I want to do this because I don't want to have a keyboard each time I start it up.
Pi taste like pie
arimal
Re: Boot into Emulationstation
Mon Oct 14, 2013 6:53 pm
There is a file "/etc/profile" You will need sudo permission to edit. At the end of that file you can include the line.
[ -n "${SSH_CONNECTION}" ] || emulationstation
This is the method used by the petrockblog retropie script.
Netram
Mon Oct 14, 2013 7:08 pm
arimal wrote:You will need sudo permission to edit.
Thank you, I think, because I don't know how to get sudo permission. I thought it was by writing "sudo -s" but when I tried to edit it i got "Permission denied". So how do I get sudo permission?
Me=n00b
Pi taste like pie
arimal
Mon Oct 14, 2013 7:13 pm
The pi user should already have them, open up a terminal type
sudo nano /etc/profile
and thats it. I might not have been very clear my bad.
chairsgotoschool
Tue Oct 15, 2013 3:16 am
dont you just open the setup for retropie then go to the setup/settings and set it to start on boot?
Netram
Tue Oct 15, 2013 9:40 am
chairsgotoschool wrote:dont you just open the setup for retropie then go to the setup/settings and set it to start on boot?
How do you do that? Because when I did like arimal said I still had to log in with pi and my password.
Pi taste like pie
arimal
Tue Oct 15, 2013 10:51 am
The directions I gave will start emulation station on login, to bypass the login see here.
http://elinux.org/RPi_Debian_Auto_Login
If you'd like to take the headache out of setting up a RetroPie take a look Petrock's excellent installation script if you have not already.
http://blog.petrockblock.com/2012/07/22 ... pberry-pi/
Netram
Tue Oct 15, 2013 1:46 pm
Thanks for all the help!
Pi taste like pie
chairsgotoschool
Tue Oct 15, 2013 4:29 pm
cd RetroPie-Setup
chmod +x retropie_setup.sh
sudo ./retropie_setup.sh
that should start the setup, then it should be the 3rd option down under the 2 options for installing retropie. then i think its one of the first options but it will say somethingl ike start emulationstation on boot
Return to “Gaming”
