welshy
Update - Stella Sound Delay Issue: Fixed!
Tue Oct 01, 2013 10:15 am
Users may have experienced/read of a Sound Delay Issue in Stella, Thread Here - http://www.raspberrypi.org/phpBB3/viewt ... 78&t=52387
It has been evident since 2013-05-25-wheezy-raspbian
Well, beta-tester has run with the problem/issue and @popcornmix has fixed it! I wont bore you with the details but if interested it is explained
Here - https://github.com/raspberrypi/linux/issues/388
The Fix: Nice and easy, update the firmware -
sudo rpi-update
sudo reboot
I have just tested with a 'Fresh' 2013-09-25-wheezy-raspbian Image and Viola! Problem eliminated! It also fixes the Pcsx-ReARMed pcm_underrun which was causing a loss of FPS. On behalf of all users, thank you guys!
I have been posting about this issue on the Forum (without reply/explanation) but was unaware of the process to identify an issue to the team responsible (apologies to all concerned). For future reference any issues can be Logged Here - https://github.com/raspberrypi/linux/issues
"The list of things I have heard now contains everything!"
Return to “Gaming”
