joacliba
Nes + performance + 2 joystick players
Sun Sep 15, 2013 3:14 pm
Hi all,
I tried some nes emulators but without luck. Some emulators don't have support for 2 player (I can't get player 2 working in retroarch), others has low performance and inaccurate colors (advmess) and others doesn't work in terminal with joystick (fceux).
So, is there any nes emulator that works without X, that has good performance and with 2 player joystick support?
Thank you ;)
welshy
Re: Nes + performance + 2 joystick players
Sun Sep 15, 2013 3:31 pm
joacliba
It does but you have to set it up correctly, use Andreys excellent Fceux port
Here - https://www.dropbox.com/s/uu751ibdqmvq0co/fceux.zip
Then follow the instructions in this Thread
http://www.raspberrypi.org/phpBB3/viewt ... ux#p406208
Although, I cannot confirm 2 Joystick set-up (I only have one). The reason certain Retro Arch cores and many other RPI forks don't support 2 players is that a lot of the emulators are GP32 ports, the handheld obviously doesn't have the facility for 2 players!
"The list of things I have heard now contains everything!"
joacliba
Sun Sep 15, 2013 5:54 pm
But:
Configure the gamepad by running fceux --inputcfg gamepad1 (In 'X' NOT Console)
This is a quote in that post.
welshy
Sun Sep 15, 2013 6:11 pm
Yes because the command starts a config set up which opens in a Window and the title bar (window decoration where the info is) isn't visible in Console. Once its set up there is no need for it again, or you can type the SDL codes straight into the config file, which is obviously more problematic!
joacliba
Sun Sep 15, 2013 6:18 pm
welshy wrote:Yes because the command starts a config set up which opens in a Window and the title bar isn't visible in Console. Once its set up there is no need for it again, or you can type the SDL codes straight into the config file, which is obviously more problematic!
Thank you, I'll try ;)
Return to “Gaming”
