hay7410
retroarch.cfg troubles
Fri Sep 13, 2013 5:53 pm
I am new to Linux based systems and recently just received my Raspberry Pi that I have been trying to turn into a retro arcade system. I have been following http://supernintendopi.wordpress.com/ mostly as well as other sites and forums attempting to get my system up and running. I have gone through the entire process twice from installing the RetroPie image to transferring roms and configuring both the ES front end controls and the configs/all/retroarch.cfg file for the emulators. The ES front end controls work fine (I am using a USB SNES controller), but after two days of researching and messing with my retroarch.cfg file I cant seem to get it to work within the emulators. The only thing that works there is hotkey/exit button combination that I set up as start and select "8" and "9" respectively. I have been testing the controls mostly in the NES emulator on super Mario games but I have tried others as well and cant get it to work. I have tried the cd RetroPie/emulators/RetroArch/tools
./retroarch-joyconfig >> ~/RetroPie/configs/all/retroarch.cfg command line and it writes to the file. Also have edited it myself adding the hotkey and deleting the extra buttons.
Please someone offer me some advice so I can get this fixed, it is driving me crazy and consuming all my thoughts!
Takenover83
Re: retroarch.cfg troubles
Sat Sep 14, 2013 1:33 am
Does your controller work when you test it? I am guessing yes if it works via emulationstation.
jstest /dev/input/js0
Your retroarch config command looks correct to me. But maybe try this one to see if it does anything different?
./retroarch-joyconfig -o p1.cfg -p 1 -j 0
sudo cat p*.cfg >> ~/RetroPie/configs/all/retroarch.cfg
hay7410
Sat Sep 14, 2013 5:42 pm
I tried jstest /dev/input/js0 and my controller is responsive to all buttons. After that I tried your ./retroarch-joyconfig -o p1.cfg -p 1 -j 0
command lines and I got the joyconfig prompts at the command screen "configuring binds for player #1 on joypad #0. after that was complete i typed sudo cat p*.cfg >> ~/RetroPie/configs/all/retroarch.cfg in the same command line still in the /RetroPie/emulators/RetroArch/tools directory and I dont think the sudo command had any action when entered (I saw no text scrolling and it just gave me a new line.
After a sudo reboot, I tried my NES roms again. ES front end controlls still navigate the menus flawlessly, but once a rom is loaded like Super Mario 3 none of the controlls respond (with the exception of select and start pressed together to kick me back out to ES).
I attached a few shots of my command lines. Maybe I'm doing something wrong but hopefully I can get this working before I give up.
Takenover83
Sat Sep 14, 2013 8:55 pm
Maybe upload your retroarch.cfg too. It looks like it should be working.
hay7410
Wed Sep 18, 2013 3:47 pm
Here is a picture of my retroarch file. I can upload the file or text later when I am at home with my SSH program.
hay7410
Wed Oct 02, 2013 7:49 pm
Still no luck. Out of ideas but don't want to throw in the towel.
Return to “Gaming”
