mrpi64
Submit you Minecraft Pi Edition questions here!
Tue Sep 10, 2013 4:15 pm
Any questions you have related to MCPI? submit them here, and I will do my best to answer them!!! ;)
http://bit.ly/mcpi-hg
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
nexusrex
Re: Submit you Minecraft Pi Edition questions here!
Tue Sep 10, 2013 4:24 pm
Page Not Found
mrpi64
Tue Sep 10, 2013 4:30 pm
nexusrex wrote:Page Not Found
What? Sorry, you must have put in a wrong internet link!
I'm happy to help.
WebKarnage
Tue Sep 10, 2013 4:38 pm
No, the user was commenting on the link in your post which appears to go nowhere.
6677
Tue Sep 10, 2013 7:00 pm
They are right. Your link is dead, the one you posted is clickable you know.... no typing error is even physically possible on our end.
But heres a question for you:
why can't I just use google or the wiki?
jonte
Fri Sep 20, 2013 9:01 am
I was trying Minecraft for the kids. I tried dragging and resizing the window and now the minecraft bitmap output is offset a bit to the upper left. I see a bit of the underlying black window. That in it self is not so bad, but the mouse cursor does not work rationally at the edges of the minecraft window.
How do I reset this? Is it in the window manager settings or in minecraft? I can't find much of either settings files in the home directory. The window position seems to be stored between restarts of minecraft and restarts of the window manager? I'm guessing if i remove the stored window settings I it will also fix the problem.
mrpi64
Sun Sep 22, 2013 2:53 pm
Well, MCPI is not open source, so you cannot know how it is structured. But my guess is this: There are 3 windows. One of them is the black bckground, and the other is an 'overlay' over the black one, displaying the graphics. The last is one that controls the mouse. The first 2 CAN be resized without problem, but I don't think that Mojang have incorporated the ability to resize the 3rd one. So, to scroll around the inventory, you have to use WASD and the enter/return keys. Black line? Many people have problems like this, and (no offence) it seems that only they have the problem. I myself have a problem with Android and XBMC. So I think that the black line is just a unique feature. I guess that you could try running the following command in the terminal (only run it is you have very little or no software that you have installed on the Pi after you got it):
sudo apt-get update && sudo apt-get upgrade
If that doesn't work, tell the kids that they have a very special Pi, one of the only that do exist.
Hope this helps. And check this MCPI map out; I made it myself:
https://www.dropbox.com/s/kxrrtmh39e7ie ... ky-Map.zip
Don't fall off the edge! :D
I'm happy to help.
6677
Sun Sep 22, 2013 7:01 pm
mrpi64 wrote:There are 3 windows.
Look at the screen. There is 1 window... There should also only be 1 draw surface within that window.
mrpi64
Mon Sep 23, 2013 7:30 am
There are at least 2. Make a python script that, lets say, turns the whole world into dirt. Run MCPI in a small/minimised window, and create a new world.. Run the script, and then move the MCPI window. See? All the graphics STAY. The black screen MOVES. There you are. 2 windows. Now you can wait a couple of minutes for MPI to finish placing all of that dirt. The 3rd one: Maximise the MCPI window, press E, and try to move the cursor to the bottom-right of the MCPI screen.
I'm happy to help.
jonte
Mon Sep 23, 2013 11:17 am
I think the window positions are cached somewhere. I just don't know where... Knowing if it is the window manager or minecraft I should be looking at would help. Updating the packages probably don't affect it. Specially as minecraft is not from a package.
Resizing the underlying window also changes the size of the "game" window. Maximizing the game still leaves me with part of the underlying black window visible. My guess is the game has a sprite for the gameplay and something is ofsetting it from where it should be. Regardless of my window size I see as much of the black window.
mrpi64
Tue Sep 24, 2013 12:25 pm
jonte wrote:I think the window positions are cached somewhere. I just don't know where... Knowing if it is the window manager or minecraft I should be looking at would help. Updating the packages probably don't affect it. Specially as minecraft is not from a package.
The windows are run using the SDL library. Prove me wrong, and I will be surprised.
I'm happy to help.
DrDominodog51
Sat Nov 16, 2013 3:44 pm
I was trying to install Minecraft and the command for decompressing the .tar file does not work. Do any of you know a diffrent way to decompress the file not on the website?
thanks in Advance.
If you don't make it, it's your own damn vault. -Land of the Lost poster
mrpi64
Sat Nov 16, 2013 4:08 pm
DrDominodog51 wrote:I was trying to install Minecraft and the command for decompressing the .tar file does not work. Do any of you know a diffrent way to decompress the file not on the website?
thanks in Advance.
Try this:
Re-download it again, right click on the file, and select 'Extract here'.
I'm happy to help.
Return to “Gaming”
