welshy
Re: GAMES LIST: Games That Work On The Pi
Mon Mar 24, 2014 2:13 pm
mrpi64
Yes, but they are generally .cue/.bin (in his case load the 'cue').
"The list of things I have heard now contains everything!"
TheGreatNi
Mon Mar 24, 2014 9:56 pm
After more testing, I've found mednafen to support yet another system it didn't even know it supported (or at least isn't listed): the SG-1000!
This 8-bit 3rd generation system is an oddity, but is fully supported by mednafen with 0 lag, so it was worth mentioning.
On another note, one of the neatest things you can do with a pi is MUDs, or Multi-User Dungeons. These old-school graphicless rpgs are quite fun and can be used on the pi by installing telnet:
sudo apt-get update && sudo apt-get install telnet
You can find large lists of MUDs online (sorry, no link). You can even play them via ssh!
You also should add a few more emulators, since the perform better than the RetroArch cores, including pisnes and fceux...
mrpi64
Tue Mar 25, 2014 11:00 am
Do you mean that you can't find a link, or you can't post it?
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
cacophony555
Tue Mar 25, 2014 5:01 pm
TheGreatNi wrote: You also should add a few more emulators, since the perform better than the RetroArch cores, including pisnes and fceux...
mame4allpi performs much better than the retroarch core, and pisnes has somewhat better music reproduction (though that's probably debatable b/c they can both be really bad at times) than the retroarch core, but the fceux core is identical to fceux as far as I can tell and I haven't seen any flaws with either one.
edit: I see the fceux link you provided goes to an FCEUltra build. I was referring to this well regarded version by Audrey: https://www.dropbox.com/s/uu751ibdqmvq0co/fceux.zip
mrpi64
Thu Mar 27, 2014 11:00 am
I have to agree that pisnes has almost flawless music output.
I'm happy to help.
cacophony555
Thu Mar 27, 2014 4:10 pm
mrpi64 wrote:I have to agree that pisnes has almost flawless music output.
Play the first part of Final Fantasy 3 and you won't think that anymore. ;)
Hint: that unpleasant buzzing sound you hear actually sounds like the wind on other emulators
gbudny
Thu Mar 27, 2014 8:31 pm
I want to confirm that I ran Airline tycoon deluxe on Raspberry Pi. You need to buy Linux version of this
games from Desura if you want to play it. In my view, Installation of the game is a very easy process.
http://www.raspberrypi.org/phpBB3/viewt ... 3&p=232095
You have to change a resolution to play it, and I'm happy to inform you that a sound in this game works.
I can't understand why this game is not so popular among Raspberry Pi users like Quake 3, Minecraft, and so on.
TheGreatNi
Thu Mar 27, 2014 10:58 pm
I haven't personally used the fceux off of dropbox, so thanks for posting that here :). A copy comes with RetroPie and works better over the RetroArch FCEUmm, if I remember correctly.
On a side note, how does one configure gamepads with pisnes/snes9x? I have buttons that exit the emulator and save/load states that ruin gameplay... :?
welshy
Fri Mar 28, 2014 6:06 am
TheGreatNi
PiSNES has it own configuration file (snes9x.cfg) in its requisite folder. It uses standard SDL codes for input (you can identify them with jstest), the options are listed below
[Keyboard]
# Get codes from /usr/include/SDL/SDL_keysym.h
A_1=100
B_1=99
X_1=115
Y_1=120
L_1=97
R_1=102
START_1=13
SELECT_1=9
LEFT_1=276
RIGHT_1=275
UP_1=273
DOWN_1=274
QUIT=27
ACCEL=8
[Joystick]
# Get codes from "jstest /dev/input/js0"
# from package "joystick"
A_1=3
B_1=2
X_1=1
Y_1=0
L_1=4
R_1=6
START_1=9
SELECT_1=8
QUIT=99
ACCEL=7
QLOAD=10
QSAVE=11
#Joystick axis
JA_LR=0
JA_UD=1
[Graphics]
DisplaySmoothStretch=1
# Display Effect: 0 none, 1 scanlines, 2 phospher
# NOTE Phospher does not run at full speed
DisplayEffect=0
MaintainAspectRatio=1
DisplayBorder=0
AutoFrameskip=1
Frameskip=200
Transparency=1
CPUCycles=100
[Sound]
APUEnabled=1
# Sound rates below as index, i.e. 7=44100 (some of these produce static)
# 0, 8192, 11025, 16000, 22050, 29300, 32000, 44100
SoundPlaybackRate=7
InterpolatedSound=0
mrpi64
Thu Apr 03, 2014 7:21 am
I see that PCs (not only modern ones, but old ones too) have some kind of joystick support. Why is this? Were joysticks some kind of revolutionary device some time ago for gamers? :?:
I'm happy to help.
welshy
Thu Apr 03, 2014 10:29 am
Man that comment makes me feel OLD! Its a historical label, Arcade Games and early Consoles used Joysticks and/or rotary dials for input, the 'Joypad' only became a general standard after the release of the Nintendo Famicom/NES in 1983/1985, it was based on the control scheme of their 'Game and Watch' series.
TheGreatNi
Mon Apr 07, 2014 2:53 pm
Hi, TheGreatNi again.
After looking for a good alternative to the game tint on pi, I came across vitetris. This fun, text based tetris clone successfully compiled on pi for me. If somebody asks, I'll upload my compiled binary, but otherwise, you can compile it yourself by running the following commands:
wget http://goo.gl/ZdPTPT vitetris-0.57.tar.gz
tar xzvf vitetris-0.57.tar.gz
cd into the right folder, and...
./configure && make
Now just run "./tetris" in that folder, and you'll be running it!
If needed, I'll revise my instructions/upload my copy if it doesn't work for you ;)
Mequa
Sat Apr 12, 2014 4:50 am
A bit slow on the Pi, but you can direct Midori to http://www.google.com/pacman - click "Insert Coin". :)
It uses JavaScript. There is a version of Google Pacman somewhere which works offline too.
mrpi64
Wed Apr 23, 2014 1:50 pm
Works a bit better in the HTML5 Pi browser.
I'm happy to help.
TheGreatNi
Wed Apr 23, 2014 10:53 pm
mrpi64 wrote:Works a bit better in the HTML5 Pi browser.
I was actually going to post about that! While laggy, Chromium (via apt-get) can play HTML5 games!
mrpi64
Flash Games
Mon Apr 28, 2014 10:02 am
Using GNash (sudo apt-get install gnash), you can also play flash games. Be prepared fr a long wait, though!
I'm happy to help.
mrpi64
Mon Apr 28, 2014 10:05 am
TheGreatNi wrote:Hi, TheGreatNi again.
./configure && make
I think I might have this on my tablet (I installed C4Droid, and installed the examples, which included a text-based tetris that uses NCurses (best programming lib ever!), and also the DOSBOX source). Could you please give me a link that has a fully-compiled version for the Pi?
If you need somewhere to store the files, check out mega.co.nz - you get 50GB of storage space for free!
I'm happy to help.
mrpi64
Thu May 01, 2014 10:09 am
Can someone please compile this program (viterris)?
You need ncurses (sudo apt-get install ncurses)
And remember the licence.
I found this program in my "C4Droid demos" folder (I still highly recommend c4droid full).
Thanks in advance.
And post up a link! If you don't have anywhere to put it online, use Google Drive or MEGA (Google Drive: 15GB free storage (unlimited bandwidth), MEGA: 50GB of free storage (10GB bandwidth).
I'm happy to help.
TheGreatNi
Thu May 01, 2014 1:34 pm
mrpi64 wrote:Can someone please compile this program (viterris)?
Thanks in advance.
I have compiled binaries, but if you make them yourself, you can just type "tetris" to run it. I'll upload them later today.
EDIT: I uploaded my copy to dropbox. Link: https://dl.dropboxusercontent.com/u/931 ... .57.tar.gz
EDIT EDIT: I know you all are fully aware of Minecraft Pi Edition, so I won't talk too much about it. Two patches were released for it (awhile ago) that allowed you to play full-screen on HDMI monitors, and a sorta-working survival mode (it is said to work best when you load a world from the actual pocket edition). People have reported problems applying and using the patched versions. I have uploaded mc-pi edition, fullscreen, and survival executables, along with shell scripts to run both patched versions. To get 'em, go:
cd /home/pi
wget -O mcpi+patches.tar.gz http://goo.gl/LV4FFv
tar xzvf ./mcpi+patches.tar.gz
cd mcpi
After following these steps, use
sh ./survival.sh
To play the the survival hack and
sh ./full.sh
to play the full-screen hack (only when using your pi when connected to an HDMI monitor).
Make sure to test this out! I'd recommend adding this to the list under the first mcpi entry. None of the contents are my creations, I simply pulled together several resources and published them for ease of use...
mrpi64
Fri May 16, 2014 7:32 am
Thanks for the binaries.
The problem with the survival patch is that because it is a "Pocket Edition" based patch, whenever it detects the mouse is over an item, you start to drop it, which get's annoying. Also, the maps created are creative, and whenever you leave the map, you loose all of your items, so put them in a chest.
But, aside from those "problems", it's a great patch. I've not tried the fullscreen one.
I'm happy to help.
TheGreatNi
Sat May 17, 2014 9:28 pm
mrpi64 wrote:Thanks for the binaries.
I know what you mean, the hack isn't all that great :?
mrpi64
Mon May 19, 2014 7:28 am
It's still one small step for the RPi world!
I'm happy to help.
mrpi64
Wed May 21, 2014 7:30 am
welshy wrote:TheGreatNi
'For those of you out there wanting to play the, what, 7(?) SuperGrafx games'
Yup, lol. 5 specific Titles (Dai Makai Mura (Ghouls N Ghosts) and 1941 Counter Attack are the only ones worth playing) and 2 PCEngine/SGX hybrids!
' Have you tried emulating PC-FX? I tried downloading an iso, and the download just failed.'
No its probably the ONLY System I don't have an Emulator for. There isn't a Title for the PC-FX that I really consider worth Emulating, it may be in the Repo version of Mednafen they don't work as CD compatibility is not present (although the Core is).
Not sure if this will help, but you could extract the .ISO?
I'm happy to help.
pedroantonio123
Tue May 27, 2014 6:55 pm
Once download how do i run it
mrpi64
Tue Jun 03, 2014 11:24 am
pedroantonio123 wrote:Once download how do i run it
Run what, a game?
Usually open up a terminal, and type that games name in, then hit enter. Or it may appear under the "Games" menu in the "Start" menu-thingy.
I'm happy to help.
Return to “Gaming”
