No, I didn't install clang (might already be installed?)
glxinfo :
[email protected]:~ $ glxinfo
name of display: :0.0
libGL error: MESA-LOADER: failed to retrieve device information
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_SGI_make_current_read, GLX_SGI_swap_control
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Broadcom (0x14e4)
Device: VC4 V3D 2.1 (0xffffffff)
Version: 13.0.6
Accelerated: yes
Video memory: 926MB
Unified memory: yes
Preferred profile: compat (0x2)
Max core profile version: 0.0
Max compat profile version: 2.1
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 2.0
OpenGL vendor string: Broadcom
OpenGL renderer string: Gallium 0.4 on VC4 V3D 2.1
OpenGL version string: 2.1 Mesa 13.0.6
OpenGL shading language version string: 1.20
OpenGL extensions:
GL_AMD_shader_trinary_minmax, GL_APPLE_packed_pixels,
GL_APPLE_vertex_array_object, GL_ARB_ES2_compatibility,
GL_ARB_buffer_storage, GL_ARB_clear_buffer_object,
GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_copy_buffer, GL_ARB_debug_output, GL_ARB_depth_texture,
GL_ARB_draw_buffers, GL_ARB_draw_elements_base_vertex,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
GL_ARB_robustness, GL_ARB_sampler_objects, GL_ARB_separate_shader_objects,
GL_ARB_shader_objects, GL_ARB_shading_language_100, GL_ARB_shadow,
GL_ARB_sync, GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_transpose_matrix, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos,
GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
GL_ATI_fragment_shader, GL_ATI_separate_stencil,
GL_ATI_texture_env_combine3, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_polygon_offset, GL_EXT_provoking_vertex, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shader_integer_mix, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side,
GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_swizzle, GL_EXT_vertex_array, GL_IBM_multimode_draw_arrays,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_INGR_blend_func_separate, GL_KHR_context_flush_control, GL_KHR_debug,
GL_MESA_pack_invert, GL_MESA_window_pos, GL_NV_blend_square,
GL_NV_fog_distance, GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
GL_NV_texgen_reflection, GL_NV_texture_env_combine4,
GL_NV_texture_rectangle, GL_OES_EGL_image, GL_OES_read_format,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 2.0 Mesa 13.0.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.0.16
OpenGL ES profile extensions:
GL_APPLE_texture_max_level, GL_EXT_blend_minmax,
GL_EXT_discard_framebuffer, GL_EXT_draw_buffers,
GL_EXT_draw_elements_base_vertex, GL_EXT_map_buffer_range,
GL_EXT_multi_draw_arrays, GL_EXT_read_format_bgra,
GL_EXT_separate_shader_objects, GL_EXT_texture_border_clamp,
GL_EXT_texture_format_BGRA8888, GL_EXT_texture_type_2_10_10_10_REV,
GL_EXT_unpack_subimage, GL_KHR_context_flush_control, GL_KHR_debug,
GL_NV_draw_buffers, GL_NV_fbo_color_attachments, GL_NV_read_buffer,
GL_NV_read_depth, GL_NV_read_depth_stencil, GL_NV_read_stencil,
GL_OES_EGL_image, GL_OES_EGL_image_external, GL_OES_EGL_sync,
GL_OES_compressed_ETC1_RGB8_texture, GL_OES_depth24, GL_OES_depth_texture,
GL_OES_draw_elements_base_vertex, GL_OES_element_index_uint,
GL_OES_fbo_render_mipmap, GL_OES_get_program_binary, GL_OES_mapbuffer,
GL_OES_packed_depth_stencil, GL_OES_rgb8_rgba8, GL_OES_stencil8,
GL_OES_surfaceless_context, GL_OES_texture_3D,
GL_OES_texture_border_clamp, GL_OES_texture_npot,
GL_OES_vertex_array_object
