xxTJxx
RetroPie controller mapping
Sun Jul 21, 2013 11:33 am
Hey everyone
I've had my RPi for a little while now and I have successfully installed RetroPie and managed to configure most things to my liking so far. The only problem I'm having is I can't find any way to configure the Sega MasterSystem and Genesis control mappings. I'm currently using a PS3 controller but will switch to an Xbox 360 controller later if that matters. I've scoured the internet for any sort of information on the subject and I can't seem to find anything definitive. I might have passed by the answer unknowingly since I'm by no means an expert at Linux or terminal commands, I only started taking interest a few months back.
Any and all help would be appreciated, but I would please ask if you could explain layman term's.
Thanks in advance.
spawnsworth
Re: RetroPie controller mapping
Mon Jul 22, 2013 9:21 pm
Hi xxTJxx,
I'm having the same problem with the Genesis/Megadrive emulator also using a PS3 controller over bluetooth. For me I can only use the left analogue stick and L3 buttons which is all messed up and not how they are mapped. Not sure what the problem is but I watch with interest!
TFav
Wed Jul 24, 2013 3:06 pm
I am having the same problem. My PS3 controller works for NES, SNES, and for EmulationStation. I have tried editing the DGEN config file with no luck.
TheJesBro
Thu Jul 25, 2013 6:07 pm
I don't have an answer, but I have a suggestion. I also have a similar problem with mapping my SNES controller to DGen
Within each emulator folder there is a readme (or similarly named file) where each line starts with a "#" which voids any commands. There is a mapping chart somewhere within this file. This can be used to check to make sure your mapping format is correct.
emptybee
Thu Aug 15, 2013 11:14 am
Hi, is this the answer you are after (bottom of page):
https://github.com/petrockblog/RetroPie ... rol-Issues
Hope this helps,
empty
welshy
Thu Aug 15, 2013 11:32 am
xxTJxx
For XBox360 controllers
Link Here - https://github.com/petrockblog/RetroPie ... controller
"The list of things I have heard now contains everything!"
mrwhite
Wed Jun 10, 2015 3:56 am
emptybee wrote:Hi, is this the answer you are after (bottom of page):
Hope this helps,
empty
This isn't working. How exactly to you input the that starts ~~/opt/ i keep getting file not found
floob
Sun Jun 21, 2015 6:55 pm
Which version of RetroPie are you using?
Your dgenrc file is most likely here:
/opt/retropie/configs/megadrive
(I'm assuming you arent using picodrive)
RetroPie help videos: https://goo.gl/1IXE7N
Return to “Gaming”
