MCbookworm
Re: Jedi Knight?
Wed Jan 24, 2018 9:36 pm
Whenever I try to run the game I get this in my terminal:
JA: v1.0.1.0 linux-arm Sep 14 2013
Initialising zone memory .....
----- FS_Startup -----
Current search path:
/home/pi/.jk3-ja/base
/home/pi/Academy_Compiled/base/japlus_gla_anims.pk3 (6 files)
/home/pi/Academy_Compiled/base/assets3.pk3 (16 files)
/home/pi/Academy_Compiled/base/assets2.pk3 (62 files)
/home/pi/Academy_Compiled/base/assets1.pk3 (8320 files)
/home/pi/Academy_Compiled/base/assets0.pk3 (15346 files)
23750 files in pk3 files
execing default.cfg
couldn't exec jaconfig.cfg
couldn't exec autoexec.cfg
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Initializing OpenGL subsystem
...loading libGLES_CM.so: Starting QGL(GLES)...
using default screen 0
setting up EGL window
* failed to add service - already in use?
preflex
Re: Jedi Knight?
Sun Feb 04, 2018 5:48 am
execing default.cfg
You need to disable the VC4 OpenGL driver. To do this, you can comment out dtoverlay=vc4-kms-v3d in your /boot/config.txt, or use raspi-config.
preflex
Re: Jedi Knight?
Wed Feb 07, 2018 2:17 am
Here are builds which should work with the VC4 OpenGL driver. They are slower than the others.
Windowed mode works in Jedi Academy, but not in Jedi Outcast
Jedi Outcast:
Binary: https://mega.nz/#!Z4412CSQ!bP2ZN6AUJ3PR ... Y5AuymEYjA
Source: https://mega.nz/#!l44WkZoT!_OpME9n1O0Ov ... zey8-y7-mE
Jedi Academy:
Binary: https://mega.nz/#!h9BjTQwC!CozwDF7Joh3v ... TM13z9qyE4
Source: https://mega.nz/#!dhh0yLbC!lJd552-kifNi ... -GhOu3hzpo
dom
Re: Jedi Knight?
Thu Feb 08, 2018 3:39 pm
What is the difference in fps between the two drivers?
preflex
Re: Jedi Knight?
Wed Mar 07, 2018 5:47 am
Sorry, due to housing problems, :-( I don't know when I'll be able to check it out, because I don't currently have access to my display or a power outlet.
The difference is noticable, but not severe. Checking it out for yourself is only a quick edit to /boot/config.txt and a reboot away.
totalidiocy
Re: Jedi Knight?
Sun Mar 25, 2018 11:55 pm
I copied the base folder to the Jedi Academy directory. I've tried every driver in raspi-config, Default gives me a white screen until I Alt-F4, Full KMS loads into the main menu but all I see is white boxes, and Fake KMS does the same thing. My GPU has a memory split of 256MB of VRAM and I have a Pi 3. I have no idea what to do. :x :x :x
totalidiocy
Re: Jedi Knight?
Sat Apr 21, 2018 11:35 pm
I'm good now. :D I was putting the base folder in the wrong directory. Thank you all who were involved in this project and thank you for making it so easy!
MCbookworm
Re: Jedi Knight?
Wed May 16, 2018 9:08 am
Thanks for the help, I've got it running now.
I've also been wondering, has anyone figured out how to use mods?
totalidiocy
Re: Jedi Knight?
Mon May 28, 2018 6:07 am
I got evolution of combat 3 "working" but all the textures are white and I don't know why. :?: :?: :?:
RogerRoger420
Re: Jedi Knight?
Wed Sep 26, 2018 9:27 pm
I got the pre-compiled files in /home/pi/Jk2 I got all the assest.pk3 files in /home/pi/JK2 (also from update 1.04) and i did the library commands but when i cd to the JK2 folder and type: ./JK2SP it says that it can't run because it's missing libEGL.so library. Does anyone know what i did wrong?
d_a_v_e
Re: Jedi Knight?
Sat Oct 13, 2018 2:10 am
I'm having trouble finding the precompiled tar.gz files anywhere on the internet. When I click the links nothing happens. I have tried just using the tar command in the command line as follows: tar zxvf http://www.allt2.se/henrik_e/sw/Outcast_Compiled.tar.gz
but i get this error:
tar (child): Cannot connect to http: resolve failed
gzip: stdin: unexpected end of file
tar: Child returned status 128
tar: Error is not recoverable: exiting now
So do these files still exist or have they been pulled from the internet? I'd like to know if I want to spend time on this or if it is a lost cause. Thanks in advance for any feedback
Re: Jedi Knight?
Sat Oct 13, 2018 6:37 pm
Download fails for me. Could be a server is down, or maybe they have gone. Posting just to let you know that it's not just you.
d_a_v_e
Re: Jedi Knight?
Mon Oct 15, 2018 12:11 am
Thank you for the response. This is an old thread so it is understandable. I just wish there were more current information on how to install, or that I had more programming knowledge XD I did get the game to launch with the binary provided above and my game pak files that I own, but for some reason opengl keeps uprendering the video output to 1824 x 984 even though in the .cfg file I have it set to 640 x 420 and windowed. I read that in the terminal output. It puts out like 0.2 fps, in other words I cant even navigate the main menu. I may try downloading the source code and messing around with it a bit before I give up.
Rasilon
Re: Jedi Knight?
Tue Oct 16, 2018 8:57 pm
Did anyone make the originals? Jedi knight dark forces 1 and 2. amazing games for the time.
Ger_Pa
Re: Jedi Knight?
Tue Oct 23, 2018 1:07 pm
Most of the Jedi Knights were already ported, plus even you can play 1 and 2 using the Dosbox that has dynamic recompiler enable
Rasilon
Re: Jedi Knight?
Tue Oct 23, 2018 4:42 pm
oh right, totally forgot that.
Return to “Gaming”
