nexusrex
problem with the controller
Wed Jul 10, 2013 11:02 pm
i have vesta controller ps1 like but without r3 and l3
the playing buttons is 1234 l1 l2 r1 r2
how can i confirn the psx buttons
the neogeo buttons
the genesis buttons
the nes and the snes buttons
nexusrex
Re: problem with the controller
Fri Jul 12, 2013 12:33 pm
any help
Katamari
Fri Jul 12, 2013 12:54 pm
Depends on what you are trying to use it for/with. EmulationStation/RetroPi? PiSNES? Specific emulators but not through EmulationStation/RetroPi
If it is emulationStation/RetroPie, then check this out from the Github wiki about the topic: https://github.com/petrockblog/RetroPie ... rol-Issues. If it is for another emulator, then first search this forum for the specific emulator and read its main article which will probably have links to another website with a lot more documentation.
nexusrex
Fri Jul 12, 2013 1:20 pm
i will use retropie / emulationstation
nexusrex
Sat Jul 13, 2013 2:11 pm
no help in the wiki
i will make a portable gaming console
Katamari
Sat Jul 13, 2013 3:47 pm
If you are just trying to set up the controls for all of the consoles and you are using RetroPie, then the process is really easy. Via http://supernintendopi.wordpress.com/
Press F4 to exit EmulationStation and go back to terminal.
cd RetroPie/emulators/RetroArch/tools
./retroarch-joyconfig >> ~/RetroPie/configs/all/retroarch.cfg
Next you are going to use your controller and follow the prompts. If your controller has less buttons than the config tries to setup (My SNES controllers lack the R2/L2, R3/L3, and Joysticks), then you need to select a dummy button (I used left trigger) for the buttons you don’t have. We will edit those out later. Once this is done, it will bring you back to the terminal.
At this point, you should be ready to game with one controller. If you type sudo reboot in your terminal, it should restart, and bring you into EmulationStation on the restart. You can then use the controller to select a game and play it.
If you want a lot more advice, I would suggest reading that whole page. It explains everything you would need for RetroPie setup and explains all about setting up controllers.
nexusrex
Sat Jul 13, 2013 4:40 pm
i have a vesta controller the buttons is 1234 l1 l2 r1 r2 start select
how can i confirn it
how can i play the psx, nes, snes, neogeo, genesis, mame and gba roms
i will make a portable gaming console like ben heck's
i will open the controller how can i connect the buttons to the raspberry pi
nexusrex
Sun Jul 14, 2013 3:34 pm
i will make a portable gaming console ben heck's like
i will use the gpio or no
Return to “Gaming”
