etherbest
emulationstation --no-exit
Fri Apr 05, 2013 4:03 pm
Hey Guys,
Quick silly question, does the above work for you?
emulationstation documentation, and if I do emulationstation --help confirms, says that this should hide the exit option in the menu but I seem to always have it there regardless.
Can anyone try?
Aloshi
Re: emulationstation --no-exit
Sat Apr 06, 2013 8:15 pm
If you're using it, RetroPie doesn't actually copy a binary to /usr/bin, but instead writes a bash script. Currently, the script doesn't correctly pass arguments (proposed fix here). You can either copy that proposed fix, or just modify the /usr/bin/emulationstation script to include --no-exit yourself.
etherbest
Sun Apr 07, 2013 11:43 am
Aloshi, thanks for the reply.
I tried you suggestion and it works, one more question, what are you using to launch emulationstation directly on boot?
etherbest
Sun Apr 07, 2013 11:51 am
Sorry, just realised thats probably a question for petrockblock ;)
etherbest
Sun Apr 07, 2013 11:53 am
And actually here's the answer if anyone is interested, modify /etc/profile:
# Start Emulation Station on boot or not?
function changeBootbehaviour()
cmd=(dialog --backtitle "PetRockBlock.com - RetroPie Setup. Installation folder: $rootdir for user $user" --menu "Choose the desired boot behaviour." 22 76 16)
options=(1 "Original boot behaviour"
2 "Start Emulation Station at boot.")
choices=$("${cmd[@]}" "${options[@]}" 2>&1 >/dev/tty)
if [ "$choices" != "" ]; then
case $choices in
1) sed /etc/inittab -i -e "s|1:2345:respawn:/bin/login -f $user tty1 </dev/tty1 >/dev/tty1 2>&1|1:2345:respawn:/sbin/getty --noclear 38400 tty1|g"
sed /etc/profile -i -e "/emulationstation/d"
dialog --backtitle "PetRockBlock.com - RetroPie Setup. Installation folder: $rootdir for user $user" --msgbox "Enabled original boot behaviour." 22 76
2) sed /etc/inittab -i -e "s|1:2345:respawn:/sbin/getty --noclear 38400 tty1|1:2345:respawn:\/bin\/login -f $user tty1 \<\/dev\/tty1 \>\/dev\/tty1 2\>\&1|g"
if [ -z $(egrep -i "emulationstation$" /etc/profile) ]
then
echo "[ -n \"\${SSH_CONNECTION}\" ] || emulationstation" >> /etc/profile
fi
dialog --backtitle "PetRockBlock.com - RetroPie Setup. Installation folder: $rootdir for user $user" --msgbox "Emulation Station is now starting on boot." 22 76
esac
else
break
Return to “Gaming”
