asphixmx
Re: Atari to USB Driver
Fri Mar 27, 2015 4:35 pm
Croccy22 wrote:Hi,
Have uploaded the files you need now. https://www.dropbox.com/s/51qwrvz85mful ... .26%2B.tar
Download and un compress. Copy the kernel.img file into your /boot folder and overwrite the existing file. Then copy the 3.10.26+ folder to the /lib/modules directory on the pi.
Edit the /boot/cmdline.txt file and add usbhid.quirks=0x1292:0x4154:0x040 to the end of the line of text. Save the file and reboot your pi.
Let me know if it all works for you.
Matt.
Hi... the dropbox file is gone. Could you upload it again? Thanks!
feederchain
Fri Mar 27, 2015 4:46 pm
I think that one might be a bit old.
Check out the following post
http://blog.petrockblock.com/forums/top ... post-91680
That kernel should work for you.
asphixmx
Wed Apr 01, 2015 4:18 pm
I have a snes adapter. The second pad doesnt work. The first one does. I changed the boot/cmdline.txt as Matt said, with the according id of the snes with no results. Anyone could help? Thanks...
Edit: Never mind. I managed a workaround. Since the second pad is recognized as a third and fourth axis (left&right, up&down) and button from 8th to 15th, I changed the player 2 buttons and axis of the emulation station config file to match those values and it worked :lol:
feederchain
Thu Apr 02, 2015 12:30 am
Honestly, I didn't bother trying to get my two joysticks showing up as js0 and js1. Just set up the emulators to make it look like it was two. I didn't see a point in spending more time on it. It all works.
asphixmx
Fri Apr 03, 2015 12:28 am
feederchain wrote:Honestly, I didn't bother trying to get my two joysticks showing up as js0 and js1. Just set up the emulators to make it look like it was two. I didn't see a point in spending more time on it. It all works.
Yeah... that's what I did... didn't know I could do that.
Thanks.
mangroud
Tue Aug 09, 2016 7:54 am
feederchain wrote:Yep, successfully got everything working with this
http://www.amazon.com/Retro-Bit-Genesis ... d_sxp_f_pt
I've also posted the custom kernel that I compiled with the changes if you want to save yourself some time.
http://blog.petrockblock.com/forums/top ... post-90318
Hi mate! I am having problems installing your kernel that I found on internet. It says:
Unpacking raspberrypi-bootloader (1.20160322-1) over (1.20160322-1) ...
Replaced by files in installed package raspberrypi-kernel (1.20160523-1) ...
dpkg: dependency problems prevent configuration of raspberrypi-bootloader:
raspberrypi-kernel (1.20160523-1) breaks raspberrypi-bootloader (<< 1.20160324-1) and is installed.
Version of raspberrypi-bootloader to be configured is 1.20160322-1.
dpkg: error processing package raspberrypi-bootloader (--install):
dependency problems - leaving unconfigured
Error completing: dpkg
Can you help me please? Many thanks
feederchain
Tue Aug 09, 2016 12:38 pm
it looks from the log that you downloaded the latest one listed there (from March) unfortunately I haven't been keeping up to date because I don't have a Pi 3 and I don't update mine anymore because I didn't really need to.
If you need to I can attempt to compile a new version of the kernel tonight and post it.
feederchain
Fri Aug 12, 2016 2:10 am
Here is a link to a new custom kernel. Note that I didn't get a chance to test it. I might tonight, but figured I'd post it anyway.
https://www.dropbox.com/s/zu5ggt52upck0 ... ar.gz?dl=0
mrdlink
Sat Jun 10, 2017 4:36 pm
@feedercahin
I have a problem with your installation files. Every tim eit tries to override the bootloader it fails. What causes that problem?
feederchain
Sat Jun 10, 2017 5:07 pm
That one is pretty old. I created another in April for someone else, but they never informed me if it worked or not.
Unfortunately I moved on from using this USB adapter on my main Retropie.
But here's the link for the latest one I created
https://www.dropbox.com/s/t3lq0p32qw4l1 ... ar.gz?dl=0
Let me know if there are still issues with it and I can create a new one in the next couple days.
mrdlink
Mon Jun 12, 2017 4:40 pm
Still doesn't work for me.
Here is the error message:
Unpacking raspberrypi-bootloader (1.20170422-1) over (1.20170303-1) ...
dpkg: error processing archive raspberrypi-bootloader_1.20170422-1_armhf.deb (--install):
trying to overwrite '/boot/bcm2710-rpi-3-b.dtb', which is also in package raspberrypi-kernel 1.20170303-1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
But thanks though for the new files.
feederchain
Mon Jun 12, 2017 5:20 pm
Looks like it should be upgrading successfully. All I can think of asking right now is if you called the install with sudo?
Otherwise, I can take a closer look later today.
Which Pi are you using?
mrdlink
Mon Jun 12, 2017 5:22 pm
Yes I called "sudo ./install.sh". I needed to do "chmod +x install.sh" though.
I'm using the raspberry pi 3 model B with the latest retropie v4.2.
Ieven tried to copy it manually, but then it says "cp: failed to preserve ownership" with the command "cp -Rf -a bootloader/boot/. /boot"
mrdlink
Tue Jun 13, 2017 1:06 am
I got every package installed now. I added a --force-overwrite to every .deb install. But somehow the os/emulationstation still doesn't recognize two buttons as before from my controller adapter; the down and right button.
feederchain
Thu Jun 15, 2017 3:24 am
OK, finally got a chance to try and install this on my Pi2. Adding --force-overwrite is an issue with the tool I used to help me compile the kernel. So I'd have to look into that a bit more. As for the controller not working. All I can think of is that I must have screwed up the code change and it actually didn't get compiled in.
Right now I have limited time to work on this, but I'll see what I can do within the next few days.
mrdlink
Thu Jun 15, 2017 6:39 pm
Ok, take your time.
But do you know how to configure joydev? I read on https://github.com/msteinbeck/hid-retro ... DETAILS.md in the driver section, that you can set different values for your usb device via joydev but it's not explained how and I didn't find anything on google either.
sarahgad
Fri Jun 16, 2017 12:37 pm
Not used any usb or ssh but still could not make it work.
feederchain
Fri Jun 16, 2017 2:27 pm
I've tried to set those USB quirks while trying to fix this with not too much luck. They were supposedly supposed to be set in cmdline.txt
But maybe there are other ways to set it. That would be far easier than compiling a new kernel all the time.
feederchain
Wed Jul 12, 2017 1:16 am
Sorry for the delay.
The tool I used to help me cross compile a kernel appears to not been kept up to date, but I was able to get around the issues with the package it created, but I am not able to get the adapter to work correctly anymore. I'm obviously doing something wrong.
I'll have to look into a different way to cross compile that is a bit more friendly than what I'm doing now.
I just don't have much time to fit this tinkering in anymore.
Return to “Gaming”
Who is online
Users browsing this forum: No registered users and 11 guests
