Is there an Xbox 360 emulator for raspberry pi
Posted: Tue Jun 15, 2021 2:37 pm
by Eman108
Could there possibly be an Xbox 360 emulator for pi?
I have been looking and can't find anything.
Please help me.
Update: The Main Reason I wanted to get an Xbox 360 emulator on the pi was to play portal.
Do you think pi 4 can handle that?
Re: Is there an Xbox 360 emulator for raspberry pi
Posted: Tue Jun 15, 2021 6:14 pm
by mahjongg
No, there is no XBOX (360) emulator for the current Power levels of the PI. The PI4 can barely emulate an N64, all later game consoles are too much to ask for.
So its not strange you could not find it as it was just a pipe dream that this was possible, maybe later generations can pull this off.
for a PI to be able to emulate an XBOX360 its hardware must be about ten time as powerful as the emulated system, that is the CPU must be 10 times as fast. plus all the rest (GPU etc ) must also be laboriously emulated
Posted: Sun Aug 01, 2021 12:50 am
by Eman108
Posted: Sun Aug 01, 2021 2:02 am
by Gavinmc42
RetroPie and Twister OS are good places to check for Emulation on Pi's
https://retropie.org.uk/
https://twisteros.com/
Dolphin works?
https://dolphin-emu.org/
Those Game Boxes are serious hardware, you are expecting a $35 to emulate a $350 box?
If Moore's law still works, a Pi in 10 years might be able to do it.
Looks at 10+ year old games? Ok maybe 20 year old games :lol:
I'm still waiting for something like Battlefield 2 to make it to Pi's ;)
Hmm Xbox 360 came out in 2005, could the Pi run those games if source was ported and recompiled, not emulated?
Are there any open source Xbox 360 games?
Interesting, will this compile on Pi's yet.
https://xqemu.com/
Something to watch or to contribute too.
Just this morning I was running 7 x QEMU VM's on a Pi 400.
Not the same but VM's do run on Pi's now.
Turns out to be CPU limited not memory limited.
Aarch64 and Vulkan can get a few more FPS, that's where I spend a lot of time.
Vulkan 1.1/1.2 on Pi4 should be out this year or early next year.
Posted: Sun Aug 01, 2021 2:06 am
by RasPiGaming
The RPi can run newer console emulators than N64. Dolphin can even run on it.
Posted: Sun Aug 01, 2021 9:59 am
by Gavinmc42
Did not realise the Xbox 360 was that old, there had to be an emulator being done by someone.
https://github.com/xenia-project/xenia
64bit Linux, try with the Beta version of Raspberry OS?
Posted: Mon Aug 02, 2021 1:00 am
by leilei
Highly doubt Xenia is looking into any ARM64 recompilers at this current state (and if any, it'd be Apple M1 in mind)
Also a reminder that Xbox360 is a 7th gen console (along with the PS3). Gamecube falls into the 6th (with PS2, Xbox, Dreamcast) and we haven't even had all of that generation perfectly emulated yet on the mainstream x86 desktop Windows PCs. A pi4 can *barely* handle Dolphin and that's the fastest, bestest of the bunch.
Posted: Mon Aug 02, 2021 1:57 am
by Gavinmc42
Not really into games but a 2GHz overclocked Pi400 might be better than Pi4.
Warzone2100, 0AD and FlightGear have been my Pi benchmark testers for years.
Have not tried FG on my Pi400, too busy playing WZ.
These are not emulated but recompiled for Armhf.
Saw Serious Sam 2 on a Pi4, not bad.
Wish I had that in my old PC game collection.
Having fun learning how to compile open source games on Pi's.
Apple M1 is 64bit ARM.
Trickle down to Pi's one day?
Posted: Mon Aug 02, 2021 3:40 am
by cleverca22
the C0T rev from the pi400 is starting to go into the pi4 line, so with a proper heatsink, the pi4 should now be able to get the same overclocks as a pi400
but you have the usual issues of flushing the old revisions out of the resellers first, so you cant be sure which pi4 rev your going to get
Posted: Mon Aug 02, 2021 4:41 am
by Gavinmc42
My Pi400 does not seem hard worked at 2.0GHz.
Runs cooler than the Pi4's, I only have the one so I have not pushed it hard.
I put my Pi4's into metal heatsink cases.
I suspect my 1.1 and 1.2 versions are BO, they are old now.
Probably pointless to heatsink them much as they cannot overclock as well.
Pi4 PCB rev 1.4 is needed for C0?
Any way to tell if the newer 8GB is C0 without opening up again?
Emulation on 2.2+GHz has to be better than 1.5GHz, if it works at all ;)
Once all the B0's are flushed, will the specs/default speeds change?
Posted: Mon Aug 02, 2021 5:07 am
by cleverca22
dont have any confirmations, but i would assume it could get a new revision# to identify it
and if the firmware detects that newer revision, it could (in theory) just change the default speed, no need for the resellers to be flushed out first
Posted: Mon Aug 02, 2021 5:33 am
by Gavinmc42
https://www.raspberrypi.org/documentati ... /README.md
No info on the BCM2711C0 like the BCM2837B0
And the revision numbers don't spell it out either.
Not sure how the software can tell.
The boot eprom must know as the PCIe stuff is different on the CM4?
Posted: Mon Aug 02, 2021 6:55 am
by cleverca22
there are 2 pieces of revision info available on any pi based system (except the original pi1 rev)
root@pi400:~# hexdump -C /proc/device-tree/system/linux,revision
00000000  00 c0 31 12                                       |..1.|
00000004
root@pi400:~# vcgencmd otp_dump | grep 30:
30:00c03112
this first one, is just a 32bit int programmed into OTP at the factory, so they can tag something as being a pi4/cm4/pi400, based on what they installed the bcm2711c0 into, after fabbing the chip
we know that every CM4 and pi400 has a C0 rev, because they had that from launch day, and that will only cease to be true when either a new rev comes out, or some pre-launch alpha units leak into the market
the pi4 is the iffy one, there are currently 4 revs out (1.1, 1.2, 1.3, and 1.4), and RPF would need to assign pi4 1.5 to the bcm2711C0 variant, to make it more obvious
STATIC_COMMAND("whatareyou", "print the cpu arch", &cmd_what_are_you)
static int cmd_what_are_you(int argc, const console_cmd_args *argv) {
#ifdef ARCH_VPU
  uint32_t cpuid;
  __asm__("version %0" : "=r"(cpuid));
  printf("i am VPU with cpuid 0x%08x\n", cpuid);
#else
  puts("i am arm");
#endif
  return 0;
] whatareyou
i am VPU with cpuid 0x04000161
the VPU side also has its own cpuid opcode, that returns a constant baked into the silicon when the raw chip was being fabbed up
that code isnt easily visible to linux (had to use a custom start4.elf in this example), but shoud probably have the B0/C0 encoded into it somewhere
its just a matter of documenting what codes map to what
here is a list of vpu id's ive found on my own models:
rpi1:
0x4000104 rpi0 with wifi and headers
0x4000104 rpi1 with composite video
0x4000104 rpi1 with composite video and i2s header
rpi2:
0x4000140 rpi2 model b v1.1 2014 no composite, no wifi
rpi3:
0x4000140 rpi3 with wifi
rpi4:
0x4000160  mentioned in bootcode 2020-05-15
0x4000161  mentioned in bootcode 2020-05-15, potentially has 2 different mask roms
0x4000161  found on a B0T pi4b
0x4000162  bootcode-2020-05-15 checks for this cpuid, if present, .text.firmware_rev[0] bit 0 must be set
0x4000162  found on a C0 pi400
Posted: Mon Aug 02, 2021 7:04 am
by Gavinmc42
"cat /proc/cpuinfo" does the same thing.
Revision d03114, which just means Pi4 8GB rev 1.4 PCB
That's documented in the revision pages.
Posted: Mon Aug 02, 2021 7:12 am
by cleverca22
when running the rpi fork of linux, yeah
there is a recent thread about it being missing, due to running mainline linux instead
Posted: Mon Aug 02, 2021 7:37 am
by Gavinmc42
Rev 1.1, 1.2 1.4 is printed on the PCB.
No idea if the B0/C0 are pin for pin?
Unsolder a C0 and put it on rev 1.4 PCB?
Once it's buried under a heatsink or in a case, how to tell it's a C0?
One day there might be a D0 part that's speced to 2.5GHz?
Posted: Mon Aug 02, 2021 8:33 am
by jamesh
They are pin compatible, so the C0 can go on the 1.4 rev no problem, and does.
Posted: Mon Aug 02, 2021 8:37 am
by cleverca22
does that mean that the C0's are still rev 1.4?, how do you tell the difference from a purely software perspective?
Posted: Mon Aug 02, 2021 9:17 am
by jamesh
Dunno, probably an ID register in the chip somewhere. Will ask around.
Posted: Mon Aug 02, 2021 9:23 am
by jamesh
We interrogate the VPU, which has a C0 flag, then patch the device tree to reflect it.
Posted: Mon Aug 02, 2021 9:28 am
by cleverca22
ah, that might be the 2nd rev i pasted above, 0x04000161
related, will the official firmware have a higher default arm_freq for C0 pi4's, like the pi400? (but obviously not as high, due to a lack of heatsink)
what is patched in the DT, so a user can detect it?
Posted: Mon Aug 02, 2021 9:48 am
by jamesh
Don't know and don't know.
Posted: Mon Aug 02, 2021 5:03 pm
by leilei
I was referring to the current maturity and speed of the 6th gen console emulators that are out there (xqemu/cxbx, pcsx2, dolphin).
All of which aren't good signs of granting emulation for a 3-core 3.2ghz PowerPC console (and that's not even touching on the GPU)
Posted: Mon Aug 02, 2021 7:24 pm
by RasPiGaming
Perhaps you could try emulating a XBOX 360 emulator with box86/64?
box86.org
Posted: Mon Aug 02, 2021 9:42 pm
by leilei
Xenia needs a CPU with AVX. so most likely no.
