lloyd5-
RetroArch Joystick-config Utility Below -
Link -
https://drive.google.com/file/d/0B51Q7d ... sp=sharing
Or you could just copy/paste this on the bottom your RetroArch config (this is for an XBox360 Pad) and alter accordingly (use jstest which will indicate the correct values for your Joypad).
input_player1_joypad_index = "0"
input_player1_b_btn = "1"
input_player1_y_btn = "3"
input_player1_select_btn = "8"
input_player1_start_btn = "9"
input_player1_up_axis = "-1"
input_player1_down_axis = "+1"
input_player1_left_axis = "-0"
input_player1_right_axis = "+0"
input_player1_a_btn = "0"
input_player1_x_btn = "2"
input_player1_l_btn = "4"
input_player1_r_btn = "5"
input_player1_l2_btn = "6"
input_player1_r2_btn = "7"
input_player1_l3_btn = "6"
input_player1_r3_btn = "7"
input_player1_l_x_plus_axis = "+0"
input_player1_l_x_minus_axis = "-0"
input_player1_l_y_plus_axis = "-1"
input_player1_l_y_minus_axis = "+1"
input_player1_r_x_plus_axis = "+2"
input_player1_r_x_minus_axis = "-2"
input_player1_r_y_plus_axis = "-3"
input_player1_r_y_minus_axis = "+3"
