Hello guys,
I installed box86 as specified on the github page, installed it with sudo make install,
now, when I try to run a game, I always get the same error ...
pi@retropie:~/Desktop/papers-please $ box86 PapersPlease
Dynarec for ARM, with extension: HALF FAST_MULT EDSP NEON VFPv4 IDIVA PageSize:4096
Using default BOX86_LD_LIBRARY_PATH: ./:lib/:lib32/:x86/
Using default BOX86_PATH: ./:bin/
Counted 26 Env var
Looking for PapersPlease
Error: ./PapersPlease is not an executable file
pi@retropie:~/shovelknight $ box86 shovelknight
Counted 26 Env var
Looking for shovelknight
Error: ./shovelknight is not an executable file
Any idea what could be wrong ?
(solved) cannot run anything with box86
Re: cannot run anything with box86
Whenever I saw a certain game was "not an executable file." I was either running the x86 version or the 64 bit variant of the game.
Either way, it will not work.
If you type file [nameOfFileYouAreRunning] (e.g. file ./PapersPlease), it will tell you if it's 32 or 64 bit.
of course he's trying to run x86 binaries, that's the whole point of box86. It can and does work, I'm running Unreal Tournament '99 on my pi
Once you have made "sudo make install", you need to reboot 1 time.
After that, you can just launch your file without using" box86", so simply "./PaperPlease" should start it.
There can be 2 cases in your error: the file is an x86_64 binary or the file is a shel script (I thinks it's the second case). So just launch the file, don't mind "box86", it will launch automagical..
I started from scratch using a fully updated image .... and it working 1st try hehe
I guess my old setup was messed up or whatever.
sorry about that !
sorry about that !
