MCRPi - MineCraft for RaspberryPi
Posted: Thu Feb 20, 2020 9:10 am
by TamaTamaGoGo
MCRPi is GUI shell script and Python to use Minecraft easier on Raspberry Pi.
Minecraft for Rasbian Buster.
You can play Minecraft.
You can use Minecratt Server too.
We could compile at GitHub.
Code Review
  • Download MCRPi
You can install MCRPi with a little command
Please see all of README.md https://github.com/TamaTamaGoGo/MCRPi- ... /README.md
You can download and install with this command.
I think if you are using Sakaki's gentoo or raspbian-nspawn-64, chenge to 64bit.
sudo wget https://raw.githubusercontent.com/TamaTamaGoGo/MCRPi---MineCraft-for-RaspberryPi/Python-Latest/Install/Install
sudo chmod +x install
./install
It’s now developing...
If you have any idea, please post to this topic :idea:
Thank you for warching this topic.
Homepage https://mcrpi.tech.blog
GitHub https://github.com/TamaTamaGoGo/MCRPi-- ... aspberryPi
Re: MCPi - MineCraft for raspberryPi
Posted: Thu Feb 20, 2020 9:40 am
by rpiMike
This might help, mmlpi:
viewtopic.php?t=245947
Posted: Tue May 12, 2020 11:36 pm
by TamaTamaGoGo
Thanks! :D
I have some question about mmlpi.
How does mmlpi act as a launcher for minecraft? :?:
I mean, how mmlpi get Minecraft game?
Re: MCRPi - MineCraft for RaspberryPi
Posted: Sun May 31, 2020 7:18 pm
by Notupus
Thanks! :D
MMLPI used to download it from AWS's minecraft kind of repo, it's just how all versions do. There is a list of versions and the downloads that gets sent.
[NEWS] Now making script to Forge and OptiFine Minecraft 1.16
Posted: Thu Jun 25, 2020 8:59 am
by TamaTamaGoGo
Hey guys!
Now I am making script to Forge and OptiFine versions 1.16.
Forge versions 1.15.2 is not available now too, so if I have enough time I am planning to make that script too.
Um, I found way to open your WI-FI’s port.
That makes easier to open your port and manage it.
And that will not request to reboot your WI-FI.
That’s software is “miniupnpc”.
You can install it with only typing a little command.
sudo apt-get install miniupnpc
I think I could make script what it automatically open your 25565 port and run command with using screen.
Thanks for reading, and if you could advice somethings to me, please tell me!
Have fun times!, TamaTamaGoGo
[NOW] ToDo
Posted: Thu Jun 25, 2020 10:11 am
by TamaTamaGoGo
Hello!
Thank you for your good script!
So, I will Contribution to your projects!
Ok, I will tell you what I am trying to make.
  • Minecraft 1.15.2 with forge - It’s difficult!
  • Minecraft 1.16.1 with OptiFine - It’s easier than making forge script, P.S. I think...
  • Minecraft 1.16.1 with forge - Same level than Minecraft 1.15.2 for forge
If you have or get any information, Please Tell Me! :idea:
P.S. Now
  • Minecraft Forge sound - Solved
Salawat wrote:
Sun Jan 12, 2020 3:33 am
cp ~/.minecraft/assets/indexes/1.14.json ~/.minecraft/assets/indexes/1.14.4-forge1.14.4-28.1.0.json
That's it. Music, block sounds, and everything else is working just fine. It's just that the installer from forge forgets to do that little step. Use the run script I posted yesterday, and you should be golden.
  • Research script for running Forge - Now developing
Oh.
I need to try download Forge and OptiFine version to get Minecraft UUID and CLIENTTOKEN.
  • Research script for running OptiFine - Now developing
  • Making tutorial for Minecraft 1.15.2 for Forge - PASS
Minecraft Forge for 1.15.2 is ready!
Minecraft Forge for 1.16.1 is ready(Legacy)!
  • Making script for Minecraft 1.16.1 for OptiFine - PASS
Waiting to OptiFine 1.16.1
  • Making script for Minecraft 1.16.1 for Forge - Now
