HTML5 games lagging on pi
Posted: Tue Feb 11, 2020 2:02 pm
by Ncm123
Hi
I am trying to build a gaming pc for my 5 year old son with the raspberry pi. I wish to make a few html5 games teaching typing , math which will play without lag in the raspberry pi.
I tried playing a few games made in construct 3 but they lagged. Can anyone help me with advice on how to make html5 games that dont lag on the pi?
Thanks!
Re: HTML5 games lagging on pi
Posted: Tue Feb 11, 2020 2:10 pm
by topguy
Which browser do you test with ?
Does resizing the browser window reduce the "lag" ? ( I interpret "lag" as a low refreshrate/stuttering in the UI )
Posted: Tue Feb 11, 2020 2:37 pm
by Ncm123
I tested on chrome. I am using raspberry pi 4. Lag meaning the frame rate is low of the game and stuttering happens.
Posted: Fri Feb 14, 2020 4:40 am
by Ncm123
Well yesterday, I tried playing this game on chrome in my Pi4 machine. It hanged the PI.
https://html5games.com/Game/Element-Blo ... 6eef2fb5ed
Is there any list online which has list of html5 games working on the pi?
I even tried playing games on the scratch website - even those games lag a lot.
Posted: Sat Feb 15, 2020 7:02 pm
by clicky
Something else is wrong. I've just started it on my Pi4 and it works quite well... Maybe not 60fps but works with decent framerate...
Posted: Sat Feb 15, 2020 7:50 pm
by kerry_s
i tried that block 1, it is laggy, but if you enable "GPU rasterization" the force in all layers, in chrome://flags it's a little better. also your going to have to raise the gpu split(performance in the config) mines at 128 right now, you could try that or go higher, i don't recommend more than 256 tops. normally mines at 96 and i'm running gnome, i raised it to try the game. :D
it depends on the game, some run perfectly fine, others don't seem optimized or they have a lot of things going on(aka: trying to be to fancy).
thanks for the heads up on the site though, going to use for my niece.
Posted: Mon Feb 17, 2020 12:42 pm
by Ncm123
Hi
I am using raspberry pi 4 with one gb ram. Do you think 4 gb ram would make it better? If yes, I will obtain one.
Posted: Mon Feb 17, 2020 1:41 pm
by topguy
You should check how much of the current 1GB you are using before you splash out on a new Pi.
"htop" is a nice command to install, shows the memory usage a bit better than normal "top".
Posted: Mon Feb 17, 2020 4:00 pm
by kerry_s
i got those games going pretty good.
memory split is set at 160
dropped my resolution from 1920x1080 to 1280x800
turned on all the gpu goodies.
Posted: Wed Mar 04, 2020 12:18 pm
by Ncm123
For us also once we drop the resolution it works well.
I am trying to build a game which will run on full screen in a browser. Can I reduce the resolution only for the browser instance?
Posted: Wed Mar 04, 2020 12:32 pm
by topguy
You can not have one window in a different resolution than the rest of the desktop. ( if I understand your question correctly )
