Page 1 of 2
Minecraft Pi edition (Stretch): how to create an infinite plain of sand?
Posted: Mon Jan 13, 2020 7:14 pm
by dsyleixa123
how to create a new world, just of an infinite plain of sand?
Re: Minecraft Pi edition (Stretch): how to create an infinite plain of sand?
Posted: Mon Jan 13, 2020 7:49 pm
by rpiMike
Google found the following:
https://www.minecraftforum.net/forums/m ... map-script
import sys
import mcpi.minecraft as minecraft
import mcpi.block as block
mc = minecraft.Minecraft.create()
mc.setBlocks(-128,0,-128,128,64,128,0)
if(len(sys.argv) > 1):
    bid = int(sys.argv[1])
else:
    bid = block.SANDSTONE.id
if bid < 0 or bid > 108:
mc.setBlocks(-128,0,-128,128,-64,128,bid)
Take care as it will flatten the currently open map. You can also pass an argument: python3 flatmap.py <id>
Posted: Mon Jan 13, 2020 7:58 pm
by PeterO
I'm pretty sure that relies on having installed the libraries for the "Adventures in Minecraft" book which the OP may not have done.
PeterO
Posted: Mon Jan 13, 2020 9:12 pm
by dsyleixa123
PeterO
correct, I have just the basic "game" coming with Stretch, and a proprietary tutorial scenery (a folder called "adventskalender" in a minecraft subfolder) containing the files chunks.dat, entities.dat, and level.dat, level.dat_old)
Posted: Mon Jan 13, 2020 9:54 pm
by PeterO
If you can I suggest getting a copy of this :
https://www.amazon.co.uk/Adventures-Min ... b_title_bk
The libraries are in the downloads section at
https://www.wiley.com/en-gb/Adventures+ ... 1119439585
PeterO
Posted: Mon Jan 13, 2020 10:04 pm
by rpiMike
I didn't need to install any libraries. Worked for me.
Posted: Mon Jan 13, 2020 10:19 pm
by PeterO
I haven't got a "clean" install to check.
PeterO
Posted: Tue Jan 14, 2020 8:37 am
by dsyleixa123
IIUC, the program above patches an existing "world".
What I mean is to create a plain sand desert world from the scratch, to get a new subfolder with new game files from wich I can start at the minecraft start window arbitrarily / optionally.
(tbh, I do not understand how minecraft worlds are generated and stored by which actual files)
Posted: Tue Jan 14, 2020 9:34 am
by dsyleixa123
PS,
as it just turned out, I cannot create a 2nd subfolder of an existing game world and then load either one optionally at the minecraft start window (for testing, I simply created a copy of the existing game subfolder):
Just 1 can be chosen, not the 2nd one which is listed but greyed out, I can just instead create a new random world (what I do not want).
How to fix that?
Posted: Tue Jan 14, 2020 9:36 am
by PeterO
Sorry I can't help further. You're using things that I've not looked into.
PeterO,
Posted: Tue Jan 14, 2020 1:34 pm
by dsyleixa123
as it seems, the minecraft Pi edition is absolutely, totally crappy... :-/
Posted: Tue Jan 14, 2020 7:59 pm
by rpiMike
You select other worlds by clicking and dragging left or right to select the required world.
Posted: Tue Jan 14, 2020 8:17 pm
by rpiMike
The following code copies a Minecraft world folder to a new world folder and renames the world in the level.dat file.
I suggest backing up your original world just in case.
To run use :
python3 copyWorld.py <original world name> <new world name>
eg
python3 copyWorld.py world MikesWorld1
import os,sys,shutil
if(len(sys.argv) > 2):
    oldWorldName = sys.argv[1]
    newWorldName = sys.argv[2]
else:
    print('2 arguments required, <old world name> <new world name>')
    quit()
path = '/home/pi/.minecraft/games/com.mojang/minecraftWorlds/'
if len(newWorldName)<5:
    print('New world name must be at least 5 characters')
    quit()
if not os.path.exists(path+oldWorldName):
    print('Old world does not exist')
    quit()
if os.path.exists(path+newWorldName):
    print('New world already exists')
    quit()
# copy folder
shutil.copytree(path+oldWorldName,path+newWorldName)
os.rename(path+newWorldName+'/level.dat',path+newWorldName+'/level.dat_old2')
f = open(path+newWorldName+'/level.dat_old2','rb')
bOrig = bytearray(f.read())
bNew = bytearray()
str=''
i=0
levelNamePos=0
ignoreNext2= False
for ch in bOrig:
    str+=chr(ch)
    if levelNamePos>0 and i>levelNamePos:
        ignoreNext2 = False
        if ch==3:
            levelNamePos = 0
            newLevelName = newWorldName.encode()
            bNew.append(len(newLevelName))
            bNew.append(0)
            bNew += newLevelName
            bNew.append(ch)
    else:
        if not ignoreNext2:
          bNew.append(ch)
    if str.endswith('LevelName'):
        levelNamePos=i+2
        ignoreNext2 = True
    i+=1
fNew = open(path + newWorldName+'/level.dat','wb')
fNew.write(bNew)
fNew.close()
Posted: Tue Jan 14, 2020 8:23 pm
by PeterO
To run use :
eg
else:
    quit()
    quit()
    quit()
    quit()
# copy folder
bNew = bytearray()
str=''
i=0
levelNamePos=0
ignoreNext2= False
for ch in bOrig:
    str+=chr(ch)
        ignoreNext2 = False
        if ch==3:
            levelNamePos = 0
            bNew.append(0)
            bNew.append(ch)
    else:
        if not ignoreNext2:
          bNew.append(ch)
        levelNamePos=i+2
        ignoreNext2 = True
    i+=1
fNew.write(bNew)
fNew.close()
I think you are wasting your breath Mike. Toys seem to have been "thrown from the pram"
PeterO
Posted: Wed Jan 15, 2020 12:17 pm
by dsyleixa123
To run use :
eg
thanks a lot, I'll soon try that!
Posted: Wed Jan 15, 2020 1:37 pm
by dsyleixa123
ok, update:
started your copy tool =>
it worked! I now have a 2nd world called new01
I could load it, do some things, leave it, reload it, all is fine.
edit, update:
now also the sand desert is fine!
again, thank you very much indeed! 8-) :geek:
Posted: Thu Jan 16, 2020 12:09 pm
by dsyleixa123
@rpiMike
unfortunately your script does not create SAND blocks at (x,0,z) for all x,z in range (-255,+255)
e.g., the sand desert is limited to x>-14, the rest beyond has the ID 95 (BEDROCK_INVISIBLE)
why is that so?
how can that be fixed?
PS:
just found out:
after some time all the blocks, one after the other, seem to vanish to the abyss, starting from the edges.... :o :shock:
Posted: Thu Jan 16, 2020 1:07 pm
by rpiMike
I wonder if you closed Minecraft before the setBlocks methods had completed?
I've added some postToChat messages so that you can see then its finished.
import sys
import time
print('begin')
mc.postToChat('starting')
time.sleep(0.5)
else:
mc.postToChat('finished')
print('end')
Posted: Thu Jan 16, 2020 1:08 pm
by rpiMike
@rpiMike
why is that so?
PS:
just found out:
Oh - sand will fall if nothing is below it !
Posted: Thu Jan 16, 2020 1:29 pm
by dsyleixa123
so one will need to set a layer beneath? at which layer level and by which matter?
Posted: Thu Jan 16, 2020 1:35 pm
by rpiMike
Lowest layer of your sand should be a block that doesn't move eg cobblestone (id 1).
Is there a reason that you wanted sand?
Posted: Thu Jan 16, 2020 1:41 pm
by dsyleixa123
actually because of the light color
tbh, I don't understand the setblocks thing:
set the 2 lowest y levels to id=1....?
x from -128 to +128 ?
y from -128 to -126 ???
z from -128 to +128 ?
Posted: Thu Jan 16, 2020 1:51 pm
by rpiMike
If you just want the sand colour why not use sandstone - which won't fall.
If you were using sand, the lowest level (z=-64 y=-64) should be a block that won't fall.
setBlocks(-256,-64,-256,256,-64,256,1) # this would set lowest level z=-64 y=-64 to cobblestone
https://arghbox.wordpress.com/2013/07/0 ... ng-blocks/
Edit: My Pi3 locks up it I try a full 256 area
Posted: Thu Jan 16, 2020 1:54 pm
by dsyleixa123
ah, ok, then I'll take sandstone perhaps, I didn't suppose them to behave so differently...
at which position in the inventory is sandstone, for "repairing" purposes?
Posted: Thu Jan 16, 2020 1:57 pm
by dsyleixa123
the lowest level (z=-64)
why z?
isn't it y?
 world.setBlocks(x1,y1,z1,  x2,y2,z2,  block_type)
