disable emulationstation from boot
Posted: Tue Oct 29, 2019 5:38 pm
by darthlink
Hello everyone, here is the situation.
I have recently re-formated my pie to install the new version and everything was working perfectly.
Then i went to install retropie and that too was working ok.
My issue is that before i install retropie, when i was booting or rebooting, it always went back in to the xwindows as autologin. Now whe i boot or reboot, it goes straight into command line. Well actually it kinda goes into graphical interface for about 10 seconds then it fall back into command line.
I do know how to get back to graphic by typing: startx
That is of from when i am home but when i want to connect with VNC, i cannot reboot or else i am doomed.
I believe it is because somehow emulationstion is in the raspbian boot file and may boot in the background to be ready.
Even when i went to raspi-config to make sure it boot into desktop, it does not change anything. its still fall back to commande line after 10 seconds or so.
I would like to know if there is a way to disable emulationstation from the raspbian boot so that whenever i boot or reboot, it does not go or fall back into command lines please?
Thank you very much.
P.S. i have the raspberrypî 3 B+
Re: disable emulationstation from boot
Posted: Wed Oct 30, 2019 12:52 am
by SkywalkerSW5
I don't know for sure, but try going into the RetroPie settings ( the one that looks like raspi-config), go to Advanced Settings, and I think its EmulatonStation or boot or startup or something like that config. That should show some settings about Startup.
Posted: Wed Oct 30, 2019 1:56 am
by darthlink
Thank you very much for your reply but after all, i manage to fix it.
I had to go through emulationstation configuration to disable the splashscreen and to change the boot to desktop.
Now its all ok.
[ SOLVED ] disable emulationstation from boot
Posted: Wed Oct 30, 2019 1:58 am
by darthlink
Thx
Posted: Sat Mar 07, 2020 9:28 pm
by afcneo
Now its all ok.
How did you do it? Could you please explain better, I would like to install Retropie, but I want the Raspbian desktop to continue to start automatically.
