Vanfanel
Cavestory (NXEngine) fixed for Raspberry Pi
Sun Dec 09, 2012 7:50 pm
Hello there,
Here I bring you a new Cave Story version for the Raspberry Pi, with threaded audio to avoid stalls in previous versions.
It also uses the included libSDL version wich is compiled with a DISPMANX backend, so it's smooth (no tearing) because it uses double-buffer + vsync and full screen scaling is done in hardware.
Dowload here:
https://github.com/vanfanel/cavestory_r ... master.zip
Instructions:
-Download master.zip
-mkdir ~/cavestory
-cp master.zip ~/cavestory
-cd ~cavestory
-unzip master.zip
-rm master.zip
-./cavestory.sh
NOTE: I don't know if it works with X, no idea. I'm not interested in X, I don't use it and never will.
Please test it and report any other problems.
Original sources here:
http://nxengine.sourceforge.net
Next nxengine version will surely include the threaded audio code.
s-config
Re: Cavestory (NXEngine) fixed for Raspberry Pi
Sun Dec 09, 2012 10:54 pm
you're right! it doesn't work with X but it's okay, games run better on rpi from rasbian shell anyways.
One thing that happens in my Pi is when i start a new game, save on level 1 and die on the spikes, die on the spikes again. it locks my Pi. So I guess the lesson is don't die so much!:)
But otherwise it's great to have the music back! Thank you for the hard work in getting this working on the Pi!
Vanfanel
Mon Dec 10, 2012 2:27 pm
@s-config: I tried starting a new game and dying on the spikes several times with no lock ups at all. Have you got an idea of how to reproduce the problem? Dying on the spikes causes the ORG player to change music so this kind of error could be my fault, but I can't reproduce it.
malakai
Mon Dec 10, 2012 3:10 pm
Dying to get home to try it out :)
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
malakai
Mon Dec 10, 2012 5:15 pm
Running on Raspbian armhf off a motorola lapdock works great thank you.
After unzipping
cd /cavestory_rpi-master
then
./cavestory.sh
Played about 10 minutes no hangs right from login as promised no X Window :) always a plus
moocow1452
Wed Dec 19, 2012 11:17 pm
Been trying to port this to Android using xperia64's modded version of the NX engine (http://www.cavestory.org/forums/index.p ... r-android/) But the sounds keep on hanging up. Think we could combine our powers to get a proper port over?
SSilver2k2
Contact: Website AOL
Thu Dec 20, 2012 3:44 am
So Awesome. I hated how the version I compiled had the audio stuttering. Great Job!!!!
My blog of various geeky things - http://blog.sheasilverman.com
PiPLAY - http://piplay.org
DeskCade.com - Mini Raspberry Pi Arcade Cabinet
Cael
Sat Feb 23, 2013 3:28 am
i figured that out (first time really using HDMI for sound much less a tv w/ it.
is there a copy of the source? (so it can be added to RetroPie)
petrockblog
Tue Mar 05, 2013 6:37 pm
Has someone already set up game pad / joystick control with this and could give advice about how to do that?
fun stuff for technics enthusiasts: www.petrockblock.com
Redyam
Thu Mar 07, 2013 3:14 pm
I tried it, and the sound is there + it runs smoothly.
However, it's only a quarter screen size, and the graphics keep flashing. Any ideas why?
Trey
Tue Mar 19, 2013 9:16 am
Seems to be runny smoothly, thanks! Is it possible to disable bilinear filtering or enable joystick support? The libretro port had these things covered through retroarch, but the micro freezes were making platforming a little too challenging :P
Vanfanel
Tue Mar 19, 2013 9:28 am
@Redyman: No idea, Are you running from the console or are you using the defective thing people call X?
@Trey: joystick support depends on the nxengine itself. Will look into it and will try to disable bilinear filtering, but I don't know if It will be able to do the joystick part because the engine is not mine and I don't know the code at all so I can only make small changes.
Newk33
Sun Mar 31, 2013 11:23 pm
have the same error as Redyman:
booting my Raspi (version B) in Raspbian (wheezy) without starting X
(got a DVI 1024x768 screen hooked up on HDMI and in boot config configured at this resolution)
pi@raspberrypi ~/cavestory $ ./cavestory.sh
Loading settings...
videoinfo: desktop bpp 16
SDL_SetVideoMode: 320x240 @ 16bpp
I can start your unaccellerated version without this visual bug and scaled from commandline without X
And even stranger, when i start the new version from X that flickering is gone! but still very tiny 320x240 on screen and suffers from that unaccellerated X.
i tried to use the settings.dat from the older version when that is set to 960x720 resolution as that gave a crystal clear and nicely fitting game on screen with the older version.. but when i put that file in the new folder i get a segmentation fault when starting ./nx
any other way to set resolution? and hope the flickering can be cured
Luutifa
Tue Apr 02, 2013 5:18 pm
Yup. Same here.
Screen is small, and flickering the background (of the game, like a cave wall) trough.
This problem started when I had to make a new SD card. I have the latest Raspbian, and the latest firmware.
I hope something can be done.
Also this version is still a bit unstable.
It can crash on some sound effects, or when going from a room/place/level to another.
Sometimes so badly that I can only plug the power out.
Anyway, this is a great work. I'd just like to have it working.
dom
Tue Apr 02, 2013 5:44 pm
Gave it a quick try. Latest firmware and launched from command line.
It filled the screen, sound seemed perfect and it ran pretty quick. It's a bit too easy to die though...
Newk33
Sun Apr 07, 2013 9:49 pm
strange that it runs diffrently on other debian wheezy... or are you running some other OS, Dom?
dom
Mon Apr 08, 2013 2:14 pm
Newk³ wrote:strange that it runs diffrently on other debian wheezy... or are you running some other OS, Dom?
I'm running on standard raspbian wheezy image.
Davespice
Contact: Twitter
Tue Apr 09, 2013 5:49 pm
I've also given this a try, I'm running the Pi on a Motorola Lapdock where the screen resolution is 1366x768.
It seems to default to 320x240, but was quite smooth and playable. Sound was great too.
Although I would love to be able to specify a higher resolution, is it fixed to 320x240 because of the sound issue then?
ruadrim
Wed Apr 17, 2013 2:50 pm
I also would like a way to change the resolution and configure a joystick.
Davespice
Contact: Twitter
Mon Sep 30, 2013 8:17 pm
Folks, Cave Story is now up on the Pi Store if anyone wants it.
It's only just been approved so if a few people could test it, that would be great;
You should find it under Games.
http://store.raspberrypi.com/projects/cavestory
dexwerx
Tue Oct 08, 2013 3:10 am
seems to run smoothly, but needs game pad support - ie: a way to assign buttons.
It registers the dpad fine on my NES->USB, but the other buttons are all over.
I can't even find where it installed to look for configs?
dexwerx
Tue Oct 08, 2013 3:14 am
FYI cavestory.cfg is in
/usr/local/bin/indiecity/InstalledApps/cavestory/Full
Davespice
Contact: Twitter
Tue Oct 08, 2013 6:58 am
dexwerx wrote:FYI cavestory.cfg is in
Yep, what he said^
malcolm5054
Mon Oct 21, 2013 10:09 pm
Davespice wrote:Folks, Cave Story is now up on the Pi Store if anyone wants it.
I launched the game but it asks to either Load or New Game. Up and down arrow works but I can't get the game to start.
Pressing F1 brings up a menu but I can't find a way to use it.
Any suggestions. I am new to Raspberry Pi....bought it for my grand son, so trying to get some things working.
thanks
Malcolm
PokeEngineer
Thu Feb 21, 2019 4:00 pm
Hello there,
Dear Vanfanel,
I am currently working on an updated version of NXEngine for Raspberry Pi with bug fixes and stuff and I would very much like to have the source code to your port, as this would make my life so much easier. Can you please provide?
Also, sorry for bugging you.
Thanks,
PokeEngineer
Don't sweat it.
When in doubt, take a BYTE out of life.
8-)
Return to “Gaming”
