Is it possible to run and record Minecraft simultaneously in Raspberry Pie 4?
Posted: Mon Aug 05, 2019 1:20 pm
by Choang
I am Korean. This topic was written with the help of a Google Translator.
Therefore, please be aware that sentences can be awkward.
There are several conditions.
1. Will use the desktop for the Minecraft server separately.
2. We will run Minecraft with a lower specification.
3. The player will have a fixed position and orientation (chunk loading will be less).
Is it possible? I wonder what you think about this.
Re: Is it possible to run and record Minecraft simultaneously in Raspberry Pie 4?
Posted: Tue Aug 06, 2019 2:52 pm
by Marekkon5
If you don't mind lower FPS then you can record the VNC.
Posted: Fri Aug 09, 2019 10:11 am
by EldaKasperski
First of all, you should have the best connection and PC with modern specifications. Probably, I can suggest i7 and 16Go of ram. If you meet all these requirements then from one desktop server try to ping the other one on the other device. However, you should aware of your IP address. I would like to know more about your internet connection as well.
