AnSor1118
Re: mmlpi - Minecraft Launcher for Raspberry Pi. Versions 1.0 - 1.12+ (+ OptiFine, Forge)
Thu Dec 05, 2019 9:44 pm
I get this crash report when trying to run 1.14.3 + OptiFine. I used the libraries that jdonald provided.
---- Minecraft Crash Report ----
// I bet Cylons wouldn't have this problem.
Time: 12/4/19 3:43 PM
Description: Initializing game
java.lang.UnsatisfiedLinkError: Failed to locate library: liblwjgl32.so
at org.lwjgl.system.Library.loadSystem(Library.java:147)
at org.lwjgl.system.Library.loadSystem(Library.java:67)
at org.lwjgl.system.Library.<clinit>(Library.java:50)
at org.lwjgl.system.MemoryUtil.<clinit>(MemoryUtil.java:97)
at org.lwjgl.system.Pointer$Default.<clinit>(Pointer.java:67)
at cuh.a(MainWindow.java:123)
at com.mojang.blaze3d.platform.GLX.initGlfw(SourceFile:191)
at cvo.au(SourceFile:459)
at cvo.b(SourceFile:395)
at net.minecraft.client.main.Main.main(SourceFile:154)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at net.minecraft.launchwrapper.Launch.launch(Launch.java:159)
at net.minecraft.launchwrapper.Launch.main(Launch.java:30)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Client thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.14.3
Operating System: Linux (arm) version 4.19.86-v7l+
Java Version: 1.8.0_212, Oracle Corporation
Java VM Version: OpenJDK Client VM (mixed mode), Oracle Corporation
Memory: 24345160 bytes (23 MB) / 229257216 bytes (218 MB) up to 1060372480 bytes (1011 MB)
JVM Flags: 5 total; -Xmn128M -Xmx1024M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy
Launched Version: 1.14.3-OptiFine_HD_U_F2
LWJGL: 3.2.2 build 10
OpenGL: ~~ERROR~~ NoClassDefFoundError: Could not initialize class org.lwjgl.system.Library
GL Caps:
Using VBOs: Yes
Is Modded: Very likely; Jar signature invalidated
Type: Client (map_client.txt)
Resource Packs:
Current Language: ~~ERROR~~ NullPointerException: null
CPU: <unknown>
OptiFine Version: OptiFine_1.14.3_HD_U_F2
OptiFine Build: 20190720-172543
Render Distance Chunks: 8
Mipmaps: 4
Anisotropic Filtering: 1
Antialiasing: 0
Multitexture: false
Shaders: null
OpenGlVersion: null
OpenGlRenderer: null
OpenGlVendor: null
CpuCount: 4
Never give up,
AS
TamaTamaGoGo
Sat Mar 07, 2020 5:18 am
Um...
It’s not working...
We need to change...
I used Option, installing Forge and OptiFine...
Medium version is not working too!
Please debug this mmlpi!
Hello!
I am TamaTama.
I am Japanese, so I am not good at English. :|
Check my raspi site. :D
https://tamatechraspi.tech.blog
I am making a script of Minecraft for rasbian buster.
Search “MCPi” at forums!
Chaosdave34
Fri Mar 27, 2020 6:40 am
1.12.2 ist working, but when I try to start 1.14.4/1.15.2 I get an Error, that tells me, that OpenGL can't be found. Also when I'm using arm64 Natives.
// This is a token for 1 free hug. Redeem at your nearest Mojangsta: [~~HUG~~]
Time: 27.03.20 07:28
	at org.lwjgl.system.Pointer$Default.<clinit>(Pointer.java:61)
	at cuo.a(SourceFile:110)
	at cyc.au(SourceFile:458)
	at cyc.b(SourceFile:394)
	at net.minecraft.client.main.Main.main(SourceFile:155)
-- Head --
Stacktrace:
Details:
Stacktrace:
Details:
	Minecraft Version: 1.14.4
	Minecraft Version ID: 1.14.4
	Operating System: Linux (arm) version 4.19.108-v8+
	Java Version: 1.8.0_241, Oracle Corporation
	Java VM Version: Java HotSpot(TM) Server VM (mixed mode), Oracle Corporation
	Memory: 112558760 bytes (107 MB) / 303050752 bytes (289 MB) up to 1060372480 bytes (1011 MB)
	CPUs: 4
	Launched Version: 1.14.4
	LWJGL: 3.2.1 build 12
	GL Caps:
	Using VBOs: Yes
	Is Modded: Probably not. Jar signature remains and client brand is untouched.
	Resource Packs:
	CPU: <unknown>
#@[email protected]# Game crashed! Crash report saved to: #@[email protected]# /home/pi/mmlpi/minecraft/crash-reports/crash-2020-03-27_07.28.00-client.txt
Return to “Gaming”
