SrIzan10
Re: How to setup Minecraft 1.12.2 on Pi3 or Pi4
Mon Jul 20, 2020 1:12 pm
Hi!
I have a problem connecting to servers such as play.skycade.net and mc.hypixel.net. It says:
Internal exception: java.lang.NullPointerException
Thank You!
rpiMike
Mon Jul 20, 2020 1:44 pm
Alexander Enderman wrote:
Mon Jul 20, 2020 1:00 am
I have run Minecraft 1.12.2 on 1 gb pi 4. minecraft ran about 20 minutes before crashing
Did you have anything else running at the same time? Any error message?
rpiMike
Hi!
Thank You!
Are you using your own valid Minecraft account?
SrIzan10
Mon Jul 20, 2020 2:35 pm
Hi!
Thank You!
Yes, but I don't purchased Minecraft, it can be that?
rpiMike
Mon Jul 20, 2020 2:37 pm
Hi!
Thank You!
How have you got a valid account if you didn’t purchase it?
SrIzan10
Mon Jul 20, 2020 2:39 pm
I don't renember, it was about 2 years when i created it
rpiMike
Mon Jul 20, 2020 2:48 pm
See if you can login at https://www.minecraft.net/
SrIzan10
Mon Jul 20, 2020 2:51 pm
Yes, I can
SrIzan10
Mon Jul 20, 2020 2:56 pm
I am using a RPi 3b+, by the way
rpiMike
Mon Jul 20, 2020 3:19 pm
Double check your account details in the run script. Otherwise I don’t know.
SrIzan10
Tue Jul 21, 2020 1:02 pm
Hi!
Can I install mods in the game? Where is the folder .minecraft?
Thank you!
SrIzan10
Please help me.
Fri Aug 21, 2020 9:00 pm
I have a problem pls help.
In servers Minecraft crashes a lot.
Making PvP, in lobbies...
I reinstalled it, nothing. Put all optimized, nothing.
I am using a 3b+ with 111mb of GPU.
pigong
Sun Aug 23, 2020 11:15 pm
Thanks a lot for this! It seems to have worked flawlessly for me, RPI4 4Gig, latest Buster... I should add you made two boys of 6 and 7, who missed the mobs in the educational Minecraft Pi, terribly excited! ;-)
Btw, I added a file called minecraftjavaed.desktop in ~/.local/share/applications with this content:
[Desktop Entry]
Type=Application
Name=Minecraft Java Ed
GenericName=Vanilla Minecraft 12.2 Java Edition
Exec=/home/pi/Minecraft/runMC1_12_2_OptifineF4.sh
Icon=/usr/share/pixmaps/minecraft-pi.png
Terminal=false
Categories=Game;ActionGame;AdventureGame;RolePlaying;
NoDisplay=false
StartupNotify=true
It brings up a menu entry in the "Games" category. Clicking it tries your patience a bit (no feedback first), but after a while "Mojang" comes up, and after another while MC's start menu! Have fun, and if somebody knows how to enhance this launcher, let me know here. Thanks!
MilkyMilkyMIlky
Wed Aug 26, 2020 3:28 pm
PLEASE HELP! When I type the last command, minecraft does not start at all though i still get this:
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 703 100 539 100 164 1911 581 --:--:-- --:--:-- --:--:-- 2492
todays access token = eyJhbGciOiJIUzI1NiJ9.eyJzdWIiOiJjODdiYjViYmMwODA2MmJhMDcyMTNmNTM5ZTFkZTYyMCIsInlnZ3QiOiJmMzI0ODAyMmU4MTM0ZDdlYTU4MDRmNTA3Mzg3YjU0MiIsInNwciI6IjgwNmQ1ZTU2YmM1YTRlMmNiMjFhN2NiZTUxMTc5NjkyIiwiaXNzIjoiWWdnZHJhc2lsLUF1dGgiLCJleHAiOjE1OTg2MjgxODUsImlhdCI6MTU5ODQ1NTM4NX0.78qdrWgj71_BOAiU-3sUtwEfeY_WSibJHDiStJpTQq8
100 71 100 61 100 10 324 53 --:--:-- --:--:-- --:--:-- 377
MINECRAFT_UUID=806d5e56bc5a4e2cb21a7cbe51179692
Java HotSpot(TM) Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
[16:23:08] [main/INFO]: Loading tweak class name optifine.OptiFineTweaker
[16:23:09] [main/INFO]: Using primary tweak class name optifine.OptiFineTweaker
[16:23:09] [main/INFO]: Calling tweak class optifine.OptiFineTweaker
OptiFineTweaker: acceptOptions
OptiFineTweaker: injectIntoClassLoader
OptiFine ClassTransformer
OptiFine ZIP file: /home/pi/.minecraft/libraries/optifine/OptiFine/1.12.2_HD_U_F4/OptiFine-1.12.2_HD_U_F4.jar
OptiFineTweaker: getLaunchArguments
OptiFineTweaker: getLaunchTarget
[16:23:09] [main/INFO]: Launching wrapped minecraft {net.minecraft.client.main.Main}
[16:23:10] [main/ERROR]: Unable to launch
java.lang.reflect.InvocationTargetException: null
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_211]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_211]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_211]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_211]
at net.minecraft.launchwrapper.Launch.launch(Launch.java:159) [launchwrapper-of-2.1.jar:2.1]
at net.minecraft.launchwrapper.Launch.main(Launch.java:30) [launchwrapper-of-2.1.jar:2.1]
Caused by: java.lang.UnsatisfiedLinkError: no lwjgl in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867) ~[?:1.8.0_211]
at java.lang.Runtime.loadLibrary0(Runtime.java:870) ~[?:1.8.0_211]
at java.lang.System.loadLibrary(System.java:1122) ~[?:1.8.0_211]
at org.lwjgl.Sys$1.run(Sys.java:72) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_211]
at org.lwjgl.Sys.doLoadLibrary(Sys.java:66) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.loadLibrary(Sys.java:96) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.<clinit>(Sys.java:117) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at bib.I(SourceFile:2825) ~[bib.class:?]
at net.minecraft.client.main.Main.main(SourceFile:38) ~[Main.class:?]
... 6 more
I NEED HELP PLEEEEEEEEEAAAAAAAAAAASE
double_nathan7
Sat Aug 29, 2020 11:35 am
... 6 more
You might not have enabled GLDriver I got that problem and I just reinstalled and found my GLDriver wasnt on.
Return to “Gaming”
