Mini Melbourne for Minecraft
Posted: Fri May 24, 2019 7:04 am
by Metonics
The city of Melbourne has created a virtual mini Melbourne that runs under Minecraft:
https://metrotunnel.vic.gov.au/about-th ... -minecraft
downloads are here:
http://fuse.education.vic.gov.au/pages/ ... eminecraft
I am not a Minecraft user but would like to hear from anyone who has tried this on the raspberry Pi
I downloaded the files but it did not seem to show the Melbourne City database
Re: Mini Melbourne for Minecraft
Posted: Fri May 24, 2019 7:06 am
by fruitoftheloom
downloads are here:
By default the version of Minecraft included with Raspbian Operating System is based of the Pocket Edition, not the full fat Microsoft version !
Posted: Fri May 24, 2019 1:02 pm
by Metonics
Does that explain why it does not work on raspberry pi?
I can load minecraft and point to the mini melbourne world but nothing seems to appear
Is it possible to get the full version of minecraft so this would run?
Posted: Fri May 24, 2019 1:55 pm
by rpiMike
It is possible, however it does push the Pi to its limits and you have to reduce view distance to its lowest setting. Maybe not ideal for viewing a city. You would also need to buy a licence if you haven’t already got one.
viewtopic.php?f=78&t=186547
Posted: Sun May 26, 2019 10:43 pm
by EduElfie
Hi there, I am one of the team that created this, and I hold all the development world files. I am more than happy to try and help convert Mini Melbourne from one of the versions I have into a PE world file format that may work on the Pi.
If you would like me to explore this, please grab a Pi world for me, so I can look at the 'insides' of it, and see how I could go about converting from what I currently have.
Thanks.
Posted: Tue May 28, 2019 12:28 am
by DaveyDave1999
Thanks.
Welcome to the Raspberry Pi forums!
Heres the file you requested:
https://mega.nz/#!sagUTQIT!HPs5schrtntj ... W9Z6cJ7-rg
...And heres how it looks! :mrgreen:
Have fun!
Posted: Tue May 28, 2019 2:49 am
by HawaiianPi
Actually, it's not possible in this case. The Java Edition download is for version 1.14.1 (or later) and the Pi can only run up to 1.12.2, so unless they release a version compatible with 1.12.2 or earlier, or for Minecraft Pi Edition (which has a limited block pallet and would not look as good), you'll need something more than a Pi to view this (and considering how resource hungry 1.14.2 is, a gaming PC to actually play in it).
I did load the world in the current Java Edition version 1.14.2 on my gaming laptop, and it's pretty impressive. I've never visited Melbourne myself, so I can't say how accurate it is, but it's a very nice build with loads to explore.
Here's a screenshot (open in new tab for full size).
Building this world in Minecraft Pi Edition would be a challenge with the much more limited block pallet. And even if there was a 1.12.2 world download, viewing it at render distance 2 would not be ideal (screenshot above is render distance 32).
Posted: Tue May 28, 2019 2:50 am
by EduElfie
Have fun!
Thanks for that, and the nice welcome! I am looking into it now, and with the world you sent, I have some ideas and possible trials to run. However, there will be serious limitations.
From what I can tell, Pi edition is based on, at the latest, PE 0.8.1 which only has limited worlds. Which means, that you can have up to about 1/3rd of the current city in any given world. Second to this, it is limited to 128 blocks high, which for the most part wont be too serious an issue, but will chop off the tops of a few of the higher buildings in the city. I believe it will also lose a lot of the block palette because the blocks used to create the world just don't exist in this version.
Here are my proposed solutions (still IF I can find a tool to convert what I have to a suitable file structure) I have the 'original' stone structure that was the start of this world from the 3D data import. If I can split this into reasonable sizes that fit within the limited world size, and then convert, you can have the basic structure of the current build.
If I can succeed at that, I will also attempt the same with the current public version, and see how many blocks get lost in the conversion.
Don't hold your breathe, this is going to take me some time, and from my searching nobody has shared a successful path for converting worlds backwards this far. Doesn't necessarily mean we cannot do it, just means it is going to be a lot of trial and error to see if we can even get a process started.
Posted: Tue May 28, 2019 2:52 am
by EduElfie
If you are interested I do have it in 1.12.2 because I use it to make my renders, and had to start there for conversion up to 1.14 anyway, but the lack of dolphins mean I cannot make it a public release, only for testing purposes in this case. Let me know!
Posted: Tue May 28, 2019 3:38 am
by HawaiianPi
It is possible to get the full Java Edition version 1.12.2 running on a Raspberry Pi 2B, 3B or 3B+ model, but only at render distance 2. So a 1.12.2 world download would let people experience it on a Pi (assuming they own Java Edition). Render distance 2 isn't ideal for sightseeing, but at least Java Edition 1.12.2 doesn't have the world size and block pallet limitations of Minecraft Pi Edition.
Posted: Thu May 30, 2019 12:50 am
by DaveyDave1999
Its based off MCPE 0.6.1 :mrgreen:
