Do you have any idea about running minecraft custom clients (that are placed in versions, not mods) like Wolfram
Java HotSpot(TM) Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Error: Could not find or load main class net.minecraft.launchwrapper.Launch
Hi Tim, sorry I have never done anything with wolfram or custom clients so I have no idea unfortunately.timof121 wrote: ↑Wed Mar 11, 2020 8:08 pmHello. Now that i'm on a RPi 4 with 4GB RAM everything works very good. I used RpiMike tutorial for the first part of the tutorial. Thanks!
Thanks![]()
Np, i found a solutionDarkPlatinum wrote: ↑Tue Mar 24, 2020 2:31 pmHi Tim, sorry I have never done anything with wolfram or custom clients so I have no idea unfortunately.timof121 wrote: ↑Wed Mar 11, 2020 8:08 pmHello. Now that i'm on a RPi 4 with 4GB RAM everything works very good. I used RpiMike tutorial for the first part of the tutorial. Thanks!
Thanks![]()
pi@raspberrypi:~ $ cd ~/Minecraft/ && ./runForge1.12.sh
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 718 100 555 100 163 1516 445 --:--:-- --:--:-- --:--:-- 1967
todays access token = eyJhbGciOiJIUzI1NiJ9.eyJzdWIiOiIzYzJiNWExMGI2MGFmMTJmMmM0ZTBmNjg5ZDhjYzg1MSIsInlnZ3QiOiI3ODI4MjFmMDk5ZWE0MjQ5OGMxNGYyZjFjNWRlMjg0YiIsInNwciI6ImY2MDI0NjVjNzkyNjRlYzFhNDQ3ZTVhMjA1MWI0MDJjIiwiaXNzIjoiWWdnZHJhc2lsLUF1dGgiLCJleHAiOjE1OTMwMjEwMjksImlhdCI6MTU5Mjg0ODIyOX0.mzCg3DdxVgBQ8QmZHY8KCqBLu_X0_cclnLysAuaUJ3s
100 87 100 69 100 18 247 64 --:--:-- --:--:-- --:--:-- 311
MINECRAFT_UUID=f602465c79264ec1a447e5a2051b402c
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
[19:50:33] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLTweaker
[19:50:33] [main/ERROR]: Unable to launch
java.lang.ClassNotFoundException: net.minecraftforge.fml.common.launcher.FMLTweaker
at java.net.URLClassLoader.findClass(URLClassLoader.java:382) ~[?:1.8.0_211]
at java.lang.ClassLoader.loadClass(ClassLoader.java:424) ~[?:1.8.0_211]
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:349) ~[?:1.8.0_211]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:1.8.0_211]
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:106) ~[launchwrapper-1.12.jar:?]
at java.lang.Class.forName0(Native Method) ~[?:1.8.0_211]
at java.lang.Class.forName(Class.java:348) ~[?:1.8.0_211]
at net.minecraft.launchwrapper.Launch.launch(Launch.java:98) [launchwrapper-1.12.jar:?]
at net.minecraft.launchwrapper.Launch.main(Launch.java:28) [launchwrapper-1.12.jar:?]
Try using this launcher:TamaTamaGoGo wrote: ↑Thu Jul 02, 2020 1:01 pmHello!
I am making script for Minecraft 1.16.1-Forge 32.0.24~ , but it doesn’t work!
I found some files path was changed, and I debugged.
But I couldn’t find launchwrapper files.
I couldn’t find any launchwrapper files, so it says like script couldn’t load net.minecraft.launchwrapper I think...?
What should I do?
Actually I am using launcher 1.6.93.
It might affect?
wget https://launcher.mojang.com/v1/objects/eabbff5ff8e21250e33670924a0c5e38f47c840b/launcher.jar
Um.. yeap!rpiMike wrote: ↑Thu Jul 02, 2020 1:14 pmTry using this launcher:TamaTamaGoGo wrote: ↑Thu Jul 02, 2020 1:01 pmHello!
What should I do?
It might affect?
dominic03 wrote: ↑Sat Mar 21, 2020 3:44 pmNot working on Pi4 4GB.
Here is the error when starting the game (not from the launcher):Code: Select all
Java HotSpot(TM) Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release Error: Could not find or load main class net.minecraft.launchwrapper.Launch
java -jar launcher.jar
[16:15:19] [main/INFO]: Loading tweak class name optifine.OptiFineTweaker
[16:15:19] [main/INFO]: Using primary tweak class name optifine.OptiFineTweaker
[16:15:19] [main/INFO]: Calling tweak class optifine.OptiFineTweaker
OptiFineTweaker: acceptOptions
OptiFineTweaker: injectIntoClassLoader
OptiFine ClassTransformer
OptiFine URL: file:/home/pi/.minecraft/libraries/optifine/OptiFine/1.12.2_HD_U_C5/OptiFine-1.12.2_HD_U_C5.jar
OptiFine ZIP file: /home/pi/.minecraft/libraries/optifine/OptiFine/1.12.2_HD_U_C5/OptiFine-1.12.2_HD_U_C5.jar
OptiFineTweaker: getLaunchArguments
OptiFineTweaker: getLaunchTarget
[16:15:19] [main/INFO]: Launching wrapped minecraft {net.minecraft.client.main.Main}
Java HotSpot(TM) Client VM warning: You have loaded library /home/pi/.minecraft/versions/1.12.2-OptiFine_HD_U_C5/1.12.2-OptiFine_HD_U_C5-natives-111938730197/liblwjgl64.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
[16:15:20] [main/ERROR]: Unable to launch
java.lang.reflect.InvocationTargetException: null
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_251]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_251]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_251]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_251]
at net.minecraft.launchwrapper.Launch.launch(Launch.java:135) [launchwrapper-1.12.jar:?]
Caused by: java.lang.UnsatisfiedLinkError: /home/pi/.minecraft/versions/1.12.2-OptiFine_HD_U_C5/1.12.2-OptiFine_HD_U_C5-natives-111938730197/liblwjgl.so: /home/pi/.minecraft/versions/1.12.2-OptiFine_HD_U_C5/1.12.2-OptiFine_HD_U_C5-natives-111938730197/liblwjgl.so: cannot open shared object file: No such file or directory (Possible cause: can't load IA 32-bit .so on a ARM-bit platform)
at java.lang.ClassLoader$NativeLibrary.load(Native Method) ~[?:1.8.0_251]
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1934) ~[?:1.8.0_251]
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1850) ~[?:1.8.0_251]
at java.lang.Runtime.loadLibrary0(Runtime.java:870) ~[?:1.8.0_251]
at java.lang.System.loadLibrary(System.java:1122) ~[?:1.8.0_251]
at org.lwjgl.Sys$1.run(Sys.java:72) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_251]
at org.lwjgl.Sys.doLoadLibrary(Sys.java:66) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.loadLibrary(Sys.java:96) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.<clinit>(Sys.java:117) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at bib.I(SourceFile:2825) ~[bib.class:?]
at net.minecraft.client.main.Main.main(SourceFile:38) ~[Main.class:?]
... 6 more
half-works, hangs system at the 'joining world' stage then game crashes with no error message
