Atharva
HELP WITH 3.5 inch DISPLAY AND GPIO
Thu May 02, 2019 4:41 pm
Hello I wanted to create a handheld console with retropie and I have a waveshare 3.5 inch touchscreen display clone.The problem is that it is interfaced with gpio and i want to use some gpio for buttons as controls.Is it possible to save some pins for display as i don't want the touchscreen.Any help would be appreciated.
gordon77
Re: HELP WITH 3.5 inch DISPLAY AND GPIO
Thu May 02, 2019 4:43 pm
Which model waveshare?
Atharva
Thu May 02, 2019 4:45 pm
waveshare 3.5 inch model a
gordon77
Thu May 02, 2019 4:50 pm
If it's this one https://www.amazon.co.uk/Waveshare-Rasp ... B01HR4CL6M with a 26pin connector then l assume you should have access to gpios on pins upto 40. You will probably need a right angled cable to connect to them.
Atharva
Thu May 02, 2019 5:04 pm
but i need a joystick and four buttons i don't think they will be enough plus start shoulder buttons etc.
gordon77
Thu May 02, 2019 5:05 pm
There are 9 gpios on pins 29 to 40, not enough?
Atharva
Thu May 02, 2019 5:09 pm
need for shoulder buttons , start etc.
My calculations:
2 pins for joystick
4 pins for action buttons
2 buttons for start /stop
2 for right shoulder and left shoulder
gordon77
Thu May 02, 2019 5:18 pm
There is a schematic here https://www.waveshare.com/wiki/File:3.5 ... ematic.pdf.
Looking at the 26pin connector they don't seem to be using a few pins labelled P1 to P4 and P7 , but l have no way of guaranteeing that.
Pi pins 8,10 and 5 also appear unused.
Beyond that you maybe able to use i2c but maybe others can comment on that.
Return to “Gaming”
