ilikecheesybread
Super Crate Box
Mon Feb 25, 2019 4:35 pm
Hi, I've recentlly downloaded Super Crate Box onto my pi. For some reason, I cant get it to work. :? the directory looks like this, can anyone help??
my bod spalling :lol:
scotty101
Re: Super Crate Box
Mon Feb 25, 2019 5:09 pm
I've never heard of Super Crate Box but I'll go out on a limb and say that what you have downloaded is NOT something compatible with the raspberry pi.
Does the website you downloaded it from mention anything about supporting a. Linux b. ARM Processors c. Raspberry Pis?
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
rpiMike
Re: Super Crate Box
Mon Feb 25, 2019 5:14 pm
The Pi version is downloadable from here:
https://yoyogames.com/pi
Make sure you have your GPU Memory set to 256MB and graphics driver set to 'Legacy'
Double clicking 'SuperCrateBox' then selecting execute should work.
From the command prompt (assuming in folder /home/pi/SuperCrateBox) use:
cd ~/SuperCrateBox
./SuperCrateBox
ilikecheesybread
Re: Super Crate Box
Mon Feb 25, 2019 6:16 pm
Okay, I’ll check as soon as I can get on my pi, how do change graphics and gpu memory?? I’m quite new.. :roll:
rpiMike
Re: Super Crate Box
Mon Feb 25, 2019 6:37 pm
GPU Memory can be set in either 'Applications Menu', 'Preferences', 'Raspberry Pi Configuration' then 'Performance' tab or from the command line:
sudo raspi-config
then 'Advanced Options', 'Memory Split'
Graphics driver can only be set using command line utility 'sudo raspi-config' then 'Advanced Options', 'GL Driver' select 'Legacy'
Imperf3kt
Re: Super Crate Box
Mon Feb 25, 2019 8:29 pm
I thought one could just edit config.txt?
Of course, raspi-config is much easier.
Google is ubiquitous - Try it today, it's free!
https://opensource.com/life/16/10/how-ask-technical-questions
rpiMike
Re: Super Crate Box
Mon Feb 25, 2019 8:48 pm
Yes, for the pedantic amongst you, you can edit the \boot\config.txt to change the graphics driver. I was referring to the fact that the option is not available in the Desktop Config utility. Not for the new user though!
rpdom
Re: Super Crate Box
Tue Feb 26, 2019 5:28 am
For the really pedantic, you can edit /boot/config.txt
jaygummers
Re: Super Crate Box
Tue Feb 26, 2019 11:41 am
Yes, I would suggest you to edit the how to get free ebay gift cards
text from the boot/config.txt file.
ilikecheesybread
Re: Super Crate Box
Tue Feb 26, 2019 3:33 pm
Hmm. Doesn’t work. Nothing comes up and I can’t see anything in htop... :cry:
Am I missing something?
Last edited by ilikecheesybread on Tue Feb 26, 2019 3:40 pm, edited 1 time in total.
rpiMike
Re: Super Crate Box
Tue Feb 26, 2019 3:34 pm
If you run it from a terminal window what messages do you get?
ilikecheesybread
Re: Super Crate Box
Tue Feb 26, 2019 3:46 pm
rpiMike
Re: Super Crate Box
Tue Feb 26, 2019 4:01 pm
Assuming your using the latest Raspbian Stretch and you have MinecraftPi installed try:
LD_LIBRARY_PATH=/opt/minecraft-pi/lib/brcm ./SuperCrateBox
ilikecheesybread
Re: Super Crate Box
Tue Feb 26, 2019 4:50 pm
Thanks! To run it again, do I just type in that command or has minecraft pi been switched withsuper crate box?
rpiMike
Re: Super Crate Box
Tue Feb 26, 2019 5:10 pm
Did that work?
If so to run again repeat that line.
ilikecheesybread
Re: Super Crate Box
Tue Feb 26, 2019 6:33 pm
Did that work?
Yeah, it did. Can i add a desktop shortcut or something in the main menu or do I have to type in this in the terminal?.
rpiMike
Re: Super Crate Box
Tue Feb 26, 2019 6:40 pm
Yes, you can do either.
ilikecheesybread
Re: Super Crate Box
Tue Feb 26, 2019 7:03 pm
Thanks!
:mrgreen: :D :mrgreen:
rpiMike
Re: Super Crate Box
Fri Mar 01, 2019 11:44 am
Super Crate Box is a crazy game:
https://www.youtube.com/watch?v=qrPpkCUyTN8
Return to “Gaming”
