common763
RETRO PIE CONTROLLER CONFIG AND SETUP
Thu Jan 10, 2019 2:08 pm
I am getting all different ops on this and am new to pi. I normally run MAME off my pc so simply hit tab and menu comes up. Have a couple questions because what I thought would be the easiest thing to do is becoming the most frustrating for me which is controller config.
MAME SETUP
1-Where is the easiest most efficient folder to store roms and keep track of control configurations? Some online say final burn, others say one of the MAME, and others Arcade. I noticed in Arcade its great because you can select emulator, but when I run Final Burn for instance, I cant get the MAME config to pop up when in the game. It seems kind of time consuming to have to do control configurations for multiple emulators for multiple games situations. Maybe this is part of the process but wanted to get feedback before I spent tons of time on this.
HOME CONSOLES
2-Again, on PC I can get the NES Emulator to popup options like control config and save, so how do you do this in the Pie Interface or do you just use the input configuration from the retropie interface?
pcmanbob
Re: RETRO PIE CONTROLLER CONFIG AND SETUP
Thu Jan 10, 2019 9:28 pm
Hi.
You might be better asking this on the retropie forum or reading their comprehensive documents
https://retropie.org.uk/forum/
https://retropie.org.uk/docs/
Return to “Gaming”
