I set my GPU memory to 256, and enabled the OpenGL driver with full KMS
The console log is:
----- FS_Startup -----
We are looking in the current search path:
/home/pi/.openarena/baseoa
/usr/lib/openarena/baseoa
/usr/lib/openarena/baseoa/z_oacmp-volume1-v3.pk3 (370 files)
/usr/lib/openarena/baseoa/pak6-patch088.pk3 (711 files)
/usr/lib/openarena/baseoa/pak6-patch085.pk3 (559 files)
/usr/lib/openarena/baseoa/pak6-misc.pk3 (229 files)
/usr/lib/openarena/baseoa/pak5-TA.pk3 (139 files)
/usr/lib/openarena/baseoa/pak4-textures.pk3 (1753 files)
/usr/lib/openarena/baseoa/pak2-players.pk3 (669 files)
/usr/lib/openarena/baseoa/pak2-players-mature.pk3 (231 files)
/usr/lib/openarena/baseoa/pak1-maps.pk3 (100 files)
/usr/lib/openarena/baseoa/pak0.pk3 (1042 files)
5803 files in pk3 files
execing default.cfg
couldn't exec q3config.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
Gtk-Message: GtkDialog mapped without a transient parent. This is discouraged.
----- Client Initialization -----
Couldn't read q3history.
----- Initializing Renderer ----
Trying to load "renderer_opengl2_arm.so" from "/usr/lib/ioquake3"...
QKEY found.
----- Client Initialization Complete -----
----- R_Init -----
SDL using driver "x11"
Initializing OpenGL display
Display aspect: 1.333
...setting mode 3: 640 480
MESA-LOADER: failed to retrieve device information
* failed to add service - already in use?
I would appreciate some help, thank you!
