Gtgamewizard
Making a Gaming mouse?
Mon Oct 29, 2018 7:51 pm
Hey everyone,
First time post, I'm creating my own gaming mouse with my own 3d printed design and i'm looking for a good way to actually put a sensor buttons and scroll wheel in there.
I was wondering it would be possible to create this with a Raspberry Pi? And if so, how hard would this be / would this be low latency enough to be utilized as a gaming mouse? :|
Thanks in advance!
HawaiianPi
Re: Making a Gaming mouse?
Tue Oct 30, 2018 1:42 pm
Probably not. I think you'd be better off with a micro controller, or gutting an existing mouse and using that in your casing.
RaspbianDK
Mon Nov 12, 2018 8:28 am
Interesting question. Following.
Imperf3kt
Mon Nov 12, 2018 9:04 pm
Disregarding how you would achieve it, the Pi is not "real time" enough for this use. You may find your mouse cursor several dozen milliseconds behind your movements - disastrous for gaming in anything requiring precision.
Google is ubiquitous - learn to use it!
https://opensource.com/life/16/10/how-ask-technical-questions
Gavinmc42
Tue Nov 13, 2018 12:48 am
But would it be?
Mice use USB, there is some time used up there.
A mouse would have sensor(SPI) to USB interface micro.
Would direct SPI be faster?
With Pi's we can test this, thanks to the IO header.
https://on-winning.com/flawless-sensor- ... t-perfect/
http://www.pixart.com.tw/productsditel2 ... al%20Mouse
The extra advantage is once you make a mouse the same tech can be used for robot navigation?
The Pi can have up to 5 SPI chips with normal chip selects.
Some robot guys have used mouse sensors as mini cameras/image sensor for obstacle avoidance.
Is there a supplier of Pixart chips?
I'm dancing on Rainbows.
Imperf3kt
Tue Nov 13, 2018 2:28 am
Maybe, but what about booting it? It may take a minute before you can even use the mouse.
Gavinmc42
Tue Nov 13, 2018 6:20 am
2-3 seconds on Ultibo, less interference from Linux OS :D
Hmm use a Zero as a Mouse, another Zero as Keyboard?
Or try a Microbit? Arduino?
Return to “Gaming”
