ZMonet
Difficulty Setting Up DragonRise Zero-Delay USB Controller
Sun Sep 09, 2018 7:24 pm
I'm terribly frustrated having spent the last 5 hours trying to set up two zero-delay DragonRise USB controllers with Emulation Station/RetroPie. I am using a Rasp Pi 3.
SETUP: Two joysticks, each with two buttons each (A & B). I also have a player 1 button, one coin button, and a player 2 button.
PROBLEM: I set up everything in Emulation Station but then when I go to "Arcade" the controls don't work. My keyboard does work though. I tried hitting TAB and then setting the controls manually within the game, but the key presses/controller movement don't register. Again, my keyboard works.
I'm so close to finishing my machine, but this is holding me back. Anyone have any advice? Thanks!
brainsage
Re: Difficulty Setting Up DragonRise Zero-Delay USB Controller
Wed Oct 03, 2018 9:03 am
Hi
Have you tried setting one to SDL instead of udev (just saw the solution somewhere on Retropie forum , but can't find the link).
Thus, after you've configured your controllers, it has to dump the configurations to
/opt/retropie/configs/all/retroarch-joypads/your controller.cfg
mentioned on https://retropie.org.uk/forum/category/ ... nd-support writers for hire developers Retropie forum or something like that.
Unfortunately, I'm currently having no access to my Pi and can't check it for you. I think you may edit the configurations in the configs editor too.
David (Brain Sage Projects Manager)
Return to “Gaming”
