darkbibble
cant build quake 3 please help
Sun Aug 26, 2018 1:17 pm
i cant get quake3 to build can somebody help me. im using a pi3b with current raspbian
here is my error output
UI_CC_MISSIONPACK code/ui/ui_gameinfo.c
UI_CC_MISSIONPACK code/ui/ui_players.c
UI_CC_MISSIONPACK code/game/bg_misc.c
UI_CC_MISSIONPACK code/game/bg_lib.c
LD build/release-linux-arm/ioq3ded.arm
LD build/release-linux-arm/ioquake3.arm
LD build/release-linux-arm/baseq3/cgamearm.so
/usr/bin/ld: build/release-linux-arm/client/tr_backend.o: undefined reference to symbol 'glEnableClientState'
//opt/vc/lib/libbrcmGLESv2.so: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
Makefile:1517: recipe for target 'build/release-linux-arm/ioquake3.arm' failed
make[2]: *** [build/release-linux-arm/ioquake3.arm] Error 1
make[2]: *** Waiting for unfinished jobs....
code/ui/ui_main.c: In function ‘UI_BuildFindPlayerList’:
code/ui/ui_main.c:4133:16: warning: array subscript is below array bounds [-Warray-bounds]
    Com_sprintf(uiInfo.foundPlayerServerNames[uiInfo.numFoundPlayerServers-1], sizeof(uiInfo.foundPlayerServerAddresses[0]), "no servers found");
make[2]: Leaving directory '/home/pi/quake3'
Makefile:981: recipe for target 'targets' failed
make[1]: *** [targets] Error 2
make[1]: Leaving directory '/home/pi/quake3'
Makefile:975: recipe for target 'release' failed
make: *** [release] Error 2
[email protected]:~/quake3 $
Q; How many Windows users does it take to fix a Linux problem??
A; Whats a Linux problem
ksharindam
Re: cant build quake 3 please help
Tue Aug 28, 2018 9:08 am
Which github source are you using?
darkbibble
Tue Aug 28, 2018 12:04 pm
ksharindam
Tue Aug 28, 2018 1:40 pm
Dont use the source from Raspberry pi git. instead build from the source from the link https://github.com/RetroPie/quake3 .
Because build scripts from the raspberry pi git is not ok, and does not compile successfully.
ksharindam
Tue Aug 28, 2018 2:02 pm
To build follow these steps ...
Open terminal and run
git clone https://github.com/RetroPie/quake3.git
cd quake3
Edit the file build_rpi_raspbian.sh and go to line no 35. And remove -lvmcs_rpc_client from that line.
Now run
./build_rpi_raspbian.sh
darkbibble
Tue Aug 28, 2018 5:08 pm
cool thanks, it works
Return to “Gaming”
