ZEsarUX-7.0
Posted: Mon May 28, 2018 8:51 am
by chernandezba
Hi!
I have uploaded a new ZEsarUX stable version :)
This is ZEsarUX 7.0
There are a lot of new features added, more than ever!
You can download the source code, as well as compiled versions for Linux, Mac, Windows and Raspberry Pi from:
https://github.com/chernandezba/zesarux
The Changelog is:
Version 7.0. 25 May 2018 - Xeno edition
Added ZX-Evolution BaseConf emulation
Added BetaDisk and TR-DOS emulation
Added Spectrum +3 emulation
Added Spectrum keyboard ghosting error feature
Added ZX Spectrum Recreated keyboard support
Added improved Spectrum 16/48/+ colour palette
Added a fast spectrum core (with some features disabled) just for slow devices, like Raspberry Pi 1/Zero. Now ZEsarUX is playable on RPi1/Zero again!
Added setting to write protect IDE, MMC, ZX-Uno Flash
Added setting to show changelog when updating emulator version
Added actions to file utilities menu: Copy, Move, Rename
Added setting to disable persistent writes on IDE and MMC
Added setting to add a watermark on the display
Added setting to reduce display to a factor of 0.75. Used on RunZX event
Added setting to save spectrum screen to pbm file (black&white)
Added a setting to dump ram contents to file when exiting ZEsarUX, ideal to run automatic tests
Added setting to exit emulator after a number of seconds (--exit-after)
Added experimental simulation of the SAA1099 audio chip from the Sam Coupe
Added second Easter Egg ;)
Added third Easter Egg ;)
Improved debugging:
* new enhanced debug cpu menu: view TV electron position on screen, new default view, cursor, toggle breakpoints, run to cursor, change registers, and a lot more...
* added cpu-step-over function on debug menu (was already available from ZRCP)
* added function to write byte to file on ZEsarUX hardware debug ports
Improved ZRCP:
* run command is stopped by default when pressing a key (or sending data to the socket)
* when a breakpoint is fired on cpu-step-mode, the breakpoint condition is shown on ZRCP
Improved joystick support:
* added joystick test menu
* buttons to events and buttons to joystick configuration are saved on configuration file
Improved OSD keyboard:
* now you can press up to all 40 keys (on Spectrum/ZX80/ZX81) at the same time
* now it can be opened from any place (needs multitask on)
Improved QL emulation:
* experimental support of LOAD, LRUN command
* can now open qlay mdv microdrive image files
Improved file viewer from file utilities:
* specific file viewers for these kind of files: .tap, .zx, .zsf, .sp, .z80, .sna, .spg, .p, .o, .mmc/.ide (fat browser, plus3dos browser), .dsk, .trd, .tzx, .cdt, .flash (zxuno flash, z88 flash, superupgrade flash), .epr, .eprom
* default hexadecimal file viewer for unknown files
* conversion utility
Improved TSConf emulation:
* added TSConf DMA, line interrupt, sprites layers
* TSConf rendering: now tiles and sprites are drawn per scanline. Border drawing. Handling of scroll registers
* TSConf debugging: debug for DMA, Video registers, Video layers, Sprites, Tiles
* added TR-DOS emulation support
Improved menu interface:
* emulated machine display is no longer faded or switched to black & white when opening menu. There were different visual glitches due to this feature
* a new "tabbed" menus to improve usability and interaction with mouse, joystick and stdout driver: waveform, visualmem, ay player
* Character width can be reduced to 7,6 or 5 pixels width
* added a setting to limit menu event: enabling it you should press the menu key 3 times in a second to open the menu
* added a setting to hide directories from file selector menus, useful when you don't want the user to be able to navigate the filesystem
* Smartload: now the cursor remembers last file loaded
* added two more GUI styles: Clean and CleanInverse
Improved sprite viewer:
* now can see sprites with speccy screen format
* you can view sprites up to 512x192
* you can see tsconf sprites
* you can see pseudo hires zx81 screens
Improved TBBlue emulation:
* Added clip window registers
* Added Copper
* Added almost all next extended opcodes
* Added a setting to start TBBlue directly to a 48 rom but with all the Next features enabled, useful for fast snapshot loading
Improved AY Player: now shows waveform volume meter
Improved VU meters with decay effect on AY Player, AY Registers and Waveform
Improved text mode drivers (aalib, stdout, simpletext, curses): text settings are in different submenu, setting to set stdout/simpletext fps
Improved messages windows. You can now have an internal clipboard, press key c to copy to it. Press P on file utils to paste contents to a file
Improved frameskip: better performance, because realvideo buffer is not updated when frameskip
Improved sound: Silence detector activated by default but can be disabled
Improved top speed: loading sound is distorted when setting top speed
Improved autoload: new setting to run at top speed the reset+load"" process
Improved real tape loading: now it shows a percentage of tape loaded
Improved default configuration: when the configuration file doesn't exist, the new one has the autosave configuration setting enabled
Improved configuration parsing: if unknown setting found on configuration file, ZEsarUX will open but warns about the error, and the autosave feature is not enabled
Improved rendering on text mode drivers: now realvideo mode can render directly to black&white text. Try TSConf with --vo stdout --realvideo --autoredrawstdout
Improved Linux library dependencies: libssl is not enabled by default on compilation
Fixed ZX-Uno emulation:
* 128kb timings are the same as a Spectrum 128k. When port 1ffd enabled, port FF return FF
* Kempston port returns 0 when no kempston selected. New BIOS can be used now
Fixed TBBlue MMU when using segment 0000-3FFFH
Fixed Raster interrupts on ZX-Uno and TBBlue. Horizontal raster position was wrong
Fixed window footer when running Pentagon
Fixed panic screen: now it is shown on all machines. New design. I hope you never see it ;)
Fixed some crashes with speech enabled and opening some menus: AY Registers, AY Player, etc...
Fixed annoying sound on Dandanator rom menu
Fixed bug on Z80 cpu core, iff2 was not being reset to 0 when firing an interrupt, so reading it by using LD A,R and LD A,I affected many demos
Some other minor bugfixes and improvements
I hope you like it!
Cheers
Cesar
