elshiftos
Fuse-sdl = blank screen in Raspbian Stretch
Sat Mar 10, 2018 7:05 pm
HI!
After extensive testing in both Stretch and Jessie, I have concluded the following:
Jessie - Fuse-sdl 1.1.1 works fine
Stretch - both Fuse-sdl 1.3.2 and 1.1.1 result in a blank screen
In both instances I am running from the command line, not in the window manager. When presented with a blank screen, I am able to navigate back to the command line 'blind' by typing F1-f-x.
From what I have gleaned from various posts on the net, a blank screen could be related to a bug or 'feature' of SDL1. There are minor version number differences in the library files between the two versions of the OS, but I can't see any way to downgrade SDL1 without breaking dependencies.
Any thoughts or input on this would be much appreciated.
Thanks!
elshiftos
Re: Fuse-sdl = blank screen in Raspbian Stretch
Sat Mar 17, 2018 5:39 pm
Yay - 100 reads and it's still a mystery! :)
The moral is, stay with Jessie and avoid Stretch. It not only breaks fuse-sdl but also the shutdown switch script by 8bitjunkie.
Vanfanel
Tue Mar 20, 2018 9:50 am
Stop using outdated and bit-rotten libs like SDL1. Use an SDL2 version of FUSE, if such a thing exists, build your own SDL2 from the latest stable sources (2.0.8) and it WILL work.
Ideally, skip SDL and use the FUSE core for libretro instead. End of mistery.
Return to “Gaming”
