it runs at around 30 fps on a medium sized map.
the only problem is that it only renders the area just around you and the rest is black or invisible until you run into it.
multiplayer works.
sound works.
how should I fix this?
I'm using sdl 1.2 from the repositories, should I use sdl 2.0?
If anyone want the instructions I can post them.
Thanks.
